1635 PTO issue
   / 1635 PTO issue #1
EricMF1635
Was bush hogging today and my PTO stopped turning. Check level to make sure it didn稚 get knock to neutral but it痴 fine. Any ideas?
   / 1635 PTO issue #2
According to TractorData, you have electro-hydraulic PTO.
Basically, you select the PTO gear you want and flip a switch to turn it on. What happens a lot during bushhogging is that sticks, heavier brush and whatever can pull the wires under the tractor and cause all sorts of problems.
You may want to give a closer look under the tractor for any pulled wires. Also check the fuses.
   / 1635 PTO issue
Yep, that痴 exactly what happened. Wire pulled lose under tractor!
   / 1635 PTO issue #4
I'm glad it was an easy fix. Thanks for updating us. :thumbsup:
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
