MF 65 with g176 gas engine with cessna power steering pump what are the fittings?
   / MF 65 with g176 gas engine with cessna power steering pump what are the fittings? #1
fatb
Member
Massey Ferguson 65 Gas
anyone know the specific fittings used for both hydralic lines on pump.? jic npt sae TIA
Anyone know the thread pitch and fittings on the cylinder side also.
   / MF 65 with g176 gas engine with cessna power steering pump what are the fittings? #3
On my 1962 203 it has brake line fittings which is pipe thread ,24 TPI. . I'm not familiar with what's on your 65.
I took short pieces of brake line and brazed on a male jic fitting on one end so I could use 1/4 inch hydraulic hose with female JIC ends to make new hoses. The brake line fitting fit the steering cylinder.
It saved me from having to have special hoses made.
so they are NPT national pipe tapered?
   / MF 65 with g176 gas engine with cessna power steering pump what are the fittings? #5
no. Brake line is not a ntp or tapered thread.
It us a straight thread with a flare on the pipe/tubing. That's the fitting I have on the steering cylinders.
I can't tell you on the pump.
Take a fitting loose and post a photo.
I went to the agco parts book and couldn't find your 65
More information would help. There were often changes made within a model runs.
Photos help
ok must be sae 45 degree flares then
   / MF 65 with g176 gas engine with cessna power steering pump what are the fittings? #7
cessna only makes aircraft, some company is using the cessna name illegally!. I'd be leery of this, as parts could be suddenly stopped when the company is put out of business for using the cessna name!.
lol your silly
   / MF 65 with g176 gas engine with cessna power steering pump what are the fittings? #9
Whoa.... a MF65 with a 4 cylinder gas engine comes real close to being a "forever" tractor as was ever made.
If you have the optional power steering you must bless it everyday, as heavy steering was the downside of most tractors in that era.
Hmmm.... the old literature also mentions an optional heavy 12 speed gearbox with power shift. Did you get twice lucky?
rScotty
yes have pas power assist steering! but only 8 speed with hi low. Has a nice fel mf 200. I bought it couple three yrs ago. Just changed the oil yesterday.
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
