Another dealership assembly blunder? Or new hydraulic fitting type?
   / Another dealership assembly blunder? Or new hydraulic fitting type? #11
   / Another dealership assembly blunder? Or new hydraulic fitting type? #12
That is a factory assembly unless there was a cylinder, fitting or hose problem addressed by the dealer. Sure does look like a caplug was left in the port when the elbow was installed. Kubota outsources loader production.
So you're saying it wasn't done by the dealer, but by a loader prep guy at some other place?
   / Another dealership assembly blunder? Or new hydraulic fitting type? #15
I am saying the dealer received the loader with the cylinders and hoses installed on the loader.
Exactly. Loaders ship pre assembled from the factory with all hoses attached and couplers in place. All a dealer does is install the loader and attache the bucket and hook up the couplers to the valve and give it a shot of grease. The dealer never attaches hoses or fittings.
   / Another dealership assembly blunder? Or new hydraulic fitting type? #17
The first time I heard of Teflon tape being used was in mid 70's we were installing a 12,500 HP turbine Southern N.Mex.
and upon completing the installation. the oil pump was filling the lines and it was a method where each bearing had pressure flow sensors and alarms then shut down if not proper range. all was normal and upon first turning over to check alignment the alarms went off almost at each bearing. removing the bearing housing was a Teflon string blocking. every fitting had to be removed and cleaned off the tape. Every since then have been very careful in using.
Read my comment again....
teflon tape is acceptable on a hydraulic fitting, so long as the tape don't get stretched across the end of the fitting, IOW, the tape starts at least one thread back on the fitting
So long as it's applied correctly and not past the end of the fitting, nothing will get in the fluid stream.
Of course if the fitting and the mating fitting is Dryseal threaded, nothing is required.
   / Another dealership assembly blunder? Or new hydraulic fitting type? #18
Essentially the person using Teflon tape has to be smarter than a roll of tape.
   / Another dealership assembly blunder? Or new hydraulic fitting type? #19
Exactly. Of course that is up for conjecture as well. Some threads and comments on here make me wonder sometimes..........:eek:
   / Another dealership assembly blunder? Or new hydraulic fitting type? #20
Well, lets face it. Someone at the factory just threaded the fittings over a plastic plug. So yes, anything is possible. :)
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
