Another dealership assembly blunder? Or new hydraulic fitting type?
   / Another dealership assembly blunder? Or new hydraulic fitting type? #21
No your good I have one like that on my L47.... Just a rubber washer........ rubber washer.jpg
   / Another dealership assembly blunder? Or new hydraulic fitting type? #22
If that's an O-ring, my Deere 80 loader has an O-ring there and an additional thin nut to compress it on the fitting. If that's just a manufacturer's label, it may just be a scan code and a warning label for Californians to no injest more than 20 of these fittings at a time and that they can cause cancer in rats, tractor users, and Twitter addicts.
   / Another dealership assembly blunder? Or new hydraulic fitting type? #23
Maybe just the retaining ring from the dust cap and the cap was yanked off later?
   / Another dealership assembly blunder? Or new hydraulic fitting type? #25
You can always take the fitting out and check.
   / Another dealership assembly blunder? Or new hydraulic fitting type? #27
Also it could be a thread lubricant that squishes out as the fitting is tightened leaving that washer like ring.
   / Another dealership assembly blunder? Or new hydraulic fitting type? #28
I have seen these "rings" before. Not sure of the purpose but it's just a ring.
   / Another dealership assembly blunder? Or new hydraulic fitting type? #29
Are these machines run down an assembly line? Could the rings be left over from some sort of collation process bringing the fittings to the assembly point?
   / Another dealership assembly blunder? Or new hydraulic fitting type? #30
Yeah, that would make sense.
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
Year: 2015 Make: Toyota Model: Camry Vehicle Type: Passenger Car Mileage: 109,107 Plate: Body Type: (A51694)
Year: 2015 Make...
CAT Skid Steer (A50322)
CAT Skid Steer...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
2019 RAM 3500 (A52472)
