   / Harbor Freight Tools that don't suck #13,462
I don't care if I'm tracked. I have nothing to hide and lead a pretty dull life anyway.
Speaking of HF, they have American Flags (made in America) with embroidered stars for $5.99 each 3 foot x 5 foot or Inside track at $3.99 each, limit 5. Nice flags, bought them previously.
   / Harbor Freight Tools that don't suck #13,463
42" bolts cutters
42 in. Bolt Cutters
Bought them to cut rebar for my garage addition. Works fine. Cheap with 20% off coupon.
I have the ones with the yellow fiberglass handles and the cable cutters. Had them for years, work good. They cut wire rope, battery cables, welding cable and bolts too.
   / Harbor Freight Tools that don't suck #13,465
42" bolts cutters
42 in. Bolt Cutters
Ive had a set for about 20 years, been good.
I prefer to use the HF cutoff wheels in my Porter Cable grinder on the rebar. Cuts fast
   / Harbor Freight Tools that don't suck #13,467
Needed to cut some 2" / 10ga square tube, so I bought the Chicago Electric 14" cutoff saw. Mounted a new Diablo 14" metal cutting wheel. Felt like lots of wobble in the blade; it seemed to cut straight enough, but it didn't feel right. Thoughts?
Follow up on this: The chop saw has gotten worse as I've cut more steel with it. The wobble is getting more pronounced and the saw is now starting to have trouble cutting. Motor is bogging down more easily, like it's losing power. I've made less than a dozen cuts.
I've already boxed it up and it's going back.
Now I have to decide if I'll just go with a better chop saw, maybe from Dewalt, take a chance on the HF horizontal bandsaw, or really belly up to the bar and buy something like the Makita LC1230, which is a 12" carbide blade saw that everyone raves about. Expensive, but appears to deliver.
   / Harbor Freight Tools that don't suck #13,468
You get what you pay for. I've always thought of the CE stuff as one step above junk.
   / Harbor Freight Tools that don't suck #13,469
I see two coupons for the click type torque wrenches, one for 9.99, the other for 11.99
Why?
They also say 'reversible' which I believe someone was asking about for left handed threads.
   / Harbor Freight Tools that don't suck #13,470
I have had good results with the lower cost HF horizontal band saw. It cuts up to 6" wide. Takes a little to get it all adjusted first especially the vertical setting. Even their lowest cost band saw blades last pretty well . Break more than going dull. Gets away from all the hot pieces of metal from a chop saw which I also had, hated it so got rid of it.
Ron
2018 Isuzu FTR Landscape Dump Truck (A55852)
2018 Isuzu FTR...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
Caterpillar Quick Attach Forks (A56469)
Caterpillar Quick...
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
2016 Ford Expedition SUV (A55853)
2016 Ford...
