IH 46 Knotter not releasing
   / IH 46 Knotter not releasing #11
Thank you for the info .. However, I don't see anything that resembles a wiper arm on either side -- the bill hook rotates 360 degrees while open which must be the "release" mechanism. I read on other forums that the McCormick/IH balers do not have wiper arms like the JD.
My dad had a 46 baler when I was a kid (he sold it some 30 years ago). The knotters are notoriously finicky. I remember after he purchased it the dealer had to make several visits to get it properly tuned. Ultimately the dealership baler guru ended up riding on the frame as dad baled so he could observe and tweak the operation. That said once he got them working the knotters provided years of relatively trouble free service.
I would suggest tracking down a service manual, and perhaps speaking to someone at your local CNH dealership for tips (preferably from a crusty veteran)
One thing I do remember is that twine choice was very important. Synthetic twine always caused problems.
For diagnostic purposes you can always break open bales and hand feed the pickup to allow you to work on the machine in the off season.
Well -- some more details to report. I baled the first cutting yesterday. After about 15 bales the knotter problems went away (they did not go away in previous years). That makes me think the problem was related to rust/wear and not timing.
I continued to have problems with strings breaking, however. I tried toying with twine tension, chute compression, etc but it was fairly unpredictable. What are some other items to check for why twine would break?
Thanks
   / IH 46 Knotter not releasing #13
Thanks
Does your baler have a thrower? The first (from the bale's POV) set of rollers should have grooves aligned with the bale twines on the bale. If these got swapped out over the years with the wrong rollers the rollers they will chew on the strings and cause breakage. For a similar reason this baler does not like really long bales. Set the bale length fairly short so the thrower can get rid of the bales quickly.
   / IH 46 Knotter not releasing #14
Except that the twine is breakinf because the knots are stuck on the billhook.
Watch this video (study the slow motion segment):
International Harvester 46 knotter - YouTube
Th consider fine polishing the billhook(s) to help ensure the knots slide off like they are supposed to. How heavy are your bales. If they are too light, the twine won't follow the exiting bale. it just bounces back. The knot has to be yanked off the billhook before another tie is initiated.
Another possibility -- i looks like the twine is not cutting sharply on the inside knotter. The ends look more torn than cut.
Could this knotter problem of not releasing be caused by dull knives?
   / IH 46 Knotter not releasing #16
On most balers the knives are easily removeable and a light stoning at the correct angle will renew the edge, I stone my knives every year and I keep my knotters clean and free from chaff. They get blown off regularly (I use a battery powered leaf blower in the field) and after every bailing session, they get greased along with the entire baler. Maintenance is everything and clean knotters work much better and miss less. You need to remove the chaff and grease, looks to me like all your greaseable points are dry.
Everything is well greased. I also blow off the chaff with air compressors. But I've never sharpened or replaced the knives.
   / IH 46 Knotter not releasing #18
The twine knives are critical on these-----dad used to file them every few loads and also the little groove that gets cut in the metal will not let the knot release. -- As stated these 46's were NOT one of IH's better machines ---- 45's were even worse.----we had several of them for junk but dad always found enough parts to make one that worked fairly good for our use. We also had an old IH 50-T and it did a real good job on the ties ---- In later years dad moved up to an NH 66 and wished he would have did so years earlier.
   / IH 46 Knotter not releasing #19
Glad I have a 575 high capacity...lol I never 'file' my twine knives, always use a whetstone. Same with my twine/net round baler.
Other than coming there in person and diagnosing the issue and repairing it, Internet cures will always be tenuous. Knotters are hands on items. Hands on and knowledge is paramount and no, I'm not coming there.
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2012 PETERBILT 365 (A53843)
2012 PETERBILT 365...
AIRMAN PDS 100S COMPRESSOR (A53843)
AIRMAN PDS 100S...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
2017 MACK CHU613 PINNACLE DAY CAB (A53843)
2017 MACK CHU613...
