Protector for hydraulic filter and cooling fan for GC 1723xx, 1725xx and older GC17xx
   / Protector for hydraulic filter and cooling fan for GC 1723xx, 1725xx and older GC17xx #1
Gofast
Gold Member
Greenville SC
MF GC 1725, 2016 MF GC 1710, Belarus 300
Protector for hydraulic filter and cooling fan for GC 1705, 1710,1715, 1720, 1723E, 1723EB, 1725M, 1725MB
My recent accessory is a protector for the fan and hydraulic filter.(It is black powder coated 1/8" steel plate)
You can install your MMM without taking it off. 50 hour maintenance 3 bolts you are all set.
It also has protection if your MMM drive shaft would come loose. Uses existing holes/nuts NO drilling.
You can have just high grass get caught on the fan and shaft taking out the O-ring.
The O-ring is about $8 but the labor to replace it is $$$ just like the fan.
I made one for my GC 1710 it will also fit GC 1705, 1715, 1720
Here is the one on a GC 1723E is will also fit GC 1723EB, 1725M, 1725MB
Louisiana Tractorworks & Projects John did a video install and review on the one for GC 1710, 1705, 1715, 1720
The one for the GC 1723E, 1723EB, 1725M, 1725MB is the same
except it U bracket is shorter and four bolts go to existing nuts that are welded to the frame rails.
This makes the install quicker.
   / Protector for hydraulic filter and cooling fan for GC 1723xx, 1725xx and older GC17xx #3
How much are these and where can they be ordered?
   / Protector for hydraulic filter and cooling fan for GC 1723xx, 1725xx and older GC17xx #5
Good price, too. Bro-Tek's plate for GC is $240, and it don't look no $90 better than yours. I don't need one, but I'll spread the word about it.
Thanks! Mine should be so much better for people with a mid mount mower.
   / Protector for hydraulic filter and cooling fan for GC 1723xx, 1725xx and older GC17xx #7
Good job. It looks good.
   / Protector for hydraulic filter and cooling fan for GC 1723xx, 1725xx and older GC17xx #10
Hey Gofast, how about making one of those to fit Mahindra?!
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
2019 JOHN DEERE 8295R LOT NUMBER 181 (A53084)
2019 JOHN DEERE...
