Tapping into existing hydraulic pump to run a PTO motor
   / Tapping into existing hydraulic pump to run a PTO motor #21
Probably just trade up to bobcat toolcat 5610 to handle both implements simultaneously.
   / Tapping into existing hydraulic pump to run a PTO motor #22
I don't think you can run the front hydraulics and rear hydraulic pto at the same time though.
   / Tapping into existing hydraulic pump to run a PTO motor #23
I have a Mahindra 4510 that has 9.6GPM from the pump and 4.3GPM for the power steering. I was wondering if I could tap into the pressure line that feeds the 3 rear remotes, add a 'T' fitting and a hydraulic solenoid that I can turn on and off to power a front mount PTO motor.
1) Do I have enough flow to do this?
2) What size PTO motor should I get to run a 7ft finish mower?
3) What type/size solenoid should I buy?
4) If this isn't the thing to do, could I add a pump that is driven right off the crank? (18 spline, 1" output shaft on end of crank)
Are you cutting with full 7 ft on your finish mower?
Is this the same mower that swings around trees?
If yes I believe rule of thumb is around 5 HP per foot of cut and that varies depending on what you are cutting. Using hydraulic drive figure minimum of 15 % power loss so you would need approximately 40 Hp hydraulic input to run your mower.
For reference rule of thumb: 1 HP can produce 1 GPM @ 1,500 PSI
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
SDLL50 Loader (A47477)
2014 Nissan Murano AWD SUV (A55758)
2014 Nissan Murano...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2011 Audi Sedan (A55758)
2011 Audi Sedan...
JMR 40" Mini Root Grapple (A53316)
JMR 40" Mini Root...
