Mixed up gasoline cans
   / Mixed up gasoline cans #12
Put a bit of water in a small container, preferably a tall narrow one similar to a test tube. Mark the height of the water on the tube, now pour in 5-10x as much gas, shake and let it settle. If the separation line between fuel and water is higher after letting it sit for a few minutes, it's the ethanol gas. Reason being ethanol will mix with water and separate out..........Mike
If it's that simple .... cool.
   / Mixed up gasoline cans #13
Ethanol is the Devil's Spawn. :devil:
Does it really matter? If the non-ethanol is $4.40/gallon and the ethanol stuff is what? $3.30 a gallon? If you replace it, it's costing you less than $5.
(4 gallons * price difference)
It only matters because of the inconvenience it is causing.
The mower was running crappy, backfiring, bad idle, etc. So I drained the gas and replaced with Trufuel ethanol-free from Home Depot as a test. It immediately ran fine and i finished the grass cutting.
The Trufuel comes to about $20 per gallon at the box stores. So I took a 25 mile each-way ride to the only station in the area that has ethanol-free at the pump and picked up 5 gallon @$4.40. Regular 87 in our area is running $1.79.
I was stupid for not marking the can. Who knows, maybe I just had a bad batch with excess ethanol, I have read that can happen occasionally, and this mower always ran fine on 87 pump gas in the past.
I'll just take a guess picking the can and if it runs bad I'll know I chose the wrong one.
Thanks for the different suggestions.
   / Mixed up gasoline cans #15
If they are both fresh, I doubt you'll notice a difference. But if it bothers you I'd fill the mower with either one until it's convenient to get a refill, and dump one of the cans in your car/truck then refill it with the good stuff.
You're not lying about that. Every one of the old gas farm tractors I have would end up with tiny rust flakes in the carb bowls after setting awhile, so I would have to disassemble and clean/blow out. And then eventually the neoprene or whatever on the needle valve tips would fail and need a rebuild. Maybe an additive would have helped but now I just drain everything completely before winter storage.
Oh, there was definitely a difference and both were fresh. It would barely run on the "bad" stuff. I should have just dumped it into an almost full tank on the pickup (34 gal capacity) and been done with it.
   / Mixed up gasoline cans #18
Yes - dump it in your pickup and be done. Strange - fresh oxygenated gasoline should run just fine in your mower. If not - something is definitely wrong.
Yeah, I think the gas was bad even though it was fresh, maybe had some E85 mixed in, who knows? This mower always ran fine on regular 87 in the past.
   / Mixed up gasoline cans #20
Think the alcohol will drop out with any added water. Could take 2 clear cylinders and put the same amount of each gasoline in each. Then add some water, a small but measurable amount. Mix and then compare water levels. The water level will be higher in the ethanol blend cylinder.
Ralph
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
20" Sea Container (A47384)
20" Sea Container...
1111-A (A54756)
1111-A (A54756)
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2015 Jeep Cherokee Latitude SUV (A53424)
2015 Jeep Cherokee...
