Mahindra 2015hst slow and fast lever
   / Mahindra 2015hst slow and fast lever #1
Becharpa
Bridgton, maine
Mahindra 2015HST
My slow and fast lever is hard to go from neutral to slow or back to neutral. Any setting is a hard pull to get it into mode.
   / Mahindra 2015hst slow and fast lever #2
I assume you are talking about your high/low transmission speeds. This can be difficult on any new tractor. Come to a complete stop - go into reverse for a couple feet. Attempt the transmission speed change just as you are coming to a rolling stop in reverse. It's best to NOT attempt any transmission change while the tractor is in motion. This situation will improve as the tractor is used more.
   / Mahindra 2015hst slow and fast lever #3
My 1626HST can be a stiff shift from time to time. I just lightly push forward/reverse, then pull my foot off the peddle, then it pops right into any range (mine is 3 range).
   / Mahindra 2015hst slow and fast lever #4
I agree, a little movement to allow gear teeth to align, then come to a complete stop to shift. Not a defect, just normal routine with that gear box.
Thank you
Thank you
2015 Ford Focus (A51694)
2015 Ford Focus...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
2007 Case 580M Series 2 Loader Backhoe (A53117)
2007 Case 580M...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
