Mahindra 2015hst slow and fast lever
   / Mahindra 2015hst slow and fast lever #1
Becharpa
Bridgton, maine
Mahindra 2015HST
My slow and fast lever is hard to go from neutral to slow or back to neutral. Any setting is a hard pull to get it into mode.
   / Mahindra 2015hst slow and fast lever #2
I assume you are talking about your high/low transmission speeds. This can be difficult on any new tractor. Come to a complete stop - go into reverse for a couple feet. Attempt the transmission speed change just as you are coming to a rolling stop in reverse. It's best to NOT attempt any transmission change while the tractor is in motion. This situation will improve as the tractor is used more.
   / Mahindra 2015hst slow and fast lever #3
My 1626HST can be a stiff shift from time to time. I just lightly push forward/reverse, then pull my foot off the peddle, then it pops right into any range (mine is 3 range).
   / Mahindra 2015hst slow and fast lever #4
I agree, a little movement to allow gear teeth to align, then come to a complete stop to shift. Not a defect, just normal routine with that gear box.
Thank you
Thank you
1268 (A50490)
1268 (A50490)
Mini Forks (A50322)
Mini Forks (A50322)
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2014 AUTOCAR EXPEDITOR GARBAGE TRUCK (A51219)
2014 AUTOCAR...
