Choosing just one grease..
   / Choosing just one grease.. #1
Hysyde
Gold Member
Eastern Ontario, Canada (South of Ottawa)
Since I just have a single grease gun at home (away from the farm shop) I'm trying to find recommendations on the best all-around grease (type/brand) that I can put to just about anything without too much fear of issues.
Obviously it will be a bit of a compromise, but I don't plan on buying a second grease gun, and swapping tubes is not an effective solution, or one I think I'd even do.
At home, the main consumers of grease are my little Ford 1210 with a FEL and a few attachments that take grease, and my Kubota F2100 mower. Other than that, it's ATVs and snowmobiles, but the snowmobile don't have many zerks on them nowadays. I bought a tube of low-temp Mystic grease years ago, and predictably never used it, as again, swapping tubes isn't a real option.
I have can of aviation moly (was used to grease sliding parts on a 25mm chain gun) that I slather on the odd part that it seems appropriate (i.e. sliding parts) or in the place of anti-sieze when I don't have any on hand.
If I put only one type in my gun, what should it be?
   / Choosing just one grease.. #5
I like it , Any grease is better than none.....
   / Choosing just one grease.. #6
For many many years I used only the Ford, Lincoln, Mercury Valvoline® Moly-Fortified Multi-Purpose Grease. I have NEVER had a wheel bearing fail with this grease. It is also rated for high pressure use and is suitable for pin and joint lubrication in most instances.
https://www.autozone.com/greases-an...rd-multi-purpose-grease-tube-14-1oz/54186_0_0
That said I have gone to multiple grease guns and I keep my DeWalt gun loaded with Amalie Pro Tac+ with 5% Moly Grease for my backhoe pins. The 5% moly is too thick for wheel bearings but stays in the high pressure pins longer and require less frequent greasing.
   / Choosing just one grease.. #7
I run a Dewalt gun with general purpose grease and a Milwaukee with red hi-temp grease for pto shafts and mower spindles
   / Choosing just one grease.. #9
I only buy grease with a extreme pressure EP rating now. That's what was recommended for the backhoe. Good for everything else and costs only a little more. Been buying TSC Traveler Premium.
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2016 Hyundai Tucson (A53424)
2016 Hyundai...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2021 CATERPILLAR 226D3 SKID STEER (A52707)
2021 CATERPILLAR...
