replace grease tip with lock and lube
   / replace grease tip with lock and lube #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
i have a new milwaukee m12 grease gun, i tried to replace the stock tip to a lock and lube, but can get the stock tip off. i tried a my bench vise, but no luck, and ideas?
   / replace grease tip with lock and lube #2
Are there flats for a open end wrench on the stock tip?
   / replace grease tip with lock and lube #3
You may want to see if the LNL will even fit on all your zerks first. Many have found that they don't fit into some loader pins and a lot of backhoe pins. I ended up removing the LNL and put the standard coupler back on.
   / replace grease tip with lock and lube #4
For sure - check to see that the LNL will fit your zerks. I have MANY zerks that are in a recessed hole. The hole is not large enough for the LNL to fit. I use either the standard tip or a needle tip. If the LNL was only a tad bit smaller in diameter it would be ideal.
yes i see the flats, but i cant believe how tight it is. should i put a little heat to it.
great point on checking the new coupler first, thx
   / replace grease tip with lock and lube #6
I think some of those ends have a thread sealant that is ever bit that hard to loosen.
I have not had a Lock and Lube brand but have two other brands and for open fittings like them but as has been said they don't work with many fittings due to the access. No idea the brand now but one is very slender and the diameter is often not the issue with it, it is getting it to release. If pushes on but you must pull the outside up to release it, sort of llke hyd hose fittings and when it is down in a cover or such you end up having to remove the cover or needle nose pliers or such to release it.
   / replace grease tip with lock and lube #7
Thats the whole reason why I got the lock n lube was just so i dont have to yank the coupler off the zerks.
   / replace grease tip with lock and lube #8
Such gymnastics are not necessary with the Lock-N-Lube brand .
   / replace grease tip with lock and lube #9
I had a similar problem.
I put the stock tip in my vise vertically, so that Kroil would soak down into the threads.
2 hours later the Kroil had done it's work, and I was able to thread the stock tip off.
If you haven't used it, Kroil is magical stuff!
   / replace grease tip with lock and lube #10
I love my lock n lube-would like to buy the M18 or M12 someday but my pneumatic one is doing a fine job. They do offer other tips....if you buy from them through Amazon you get spare parts too.
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
Sakai SW880-1 (A47477)
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2009 VOLVO VNM DAY CAB (A54607)
2009 VOLVO VNM DAY...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
