warning symbol on dash - 1735m
   / warning symbol on dash - 1735m #1
pattycake
Member
Usa
MF 1735m
1725m
37 hours
I was brush-hogging a large dense field yesterday, almost 98 degrees outside, and a symbol ! in a triangle appeared on the dash. Just above the hour display, showed a 1 (one).
When it happened, the rpm immediately dropped. I stopped, shut the brush hog down, and lowered the throttle.... no change. Raising the throttle had no effect. I waited about 20 seconds then turned the engine off. After I turned it back on 10-15 seconds later, the symbol was gone and I was able to increase the throttle like normal. I headed back to the barn and parked it.
When this happened, the temperature showed 3 bars - pretty much what it always shows.
The field was very tall and very dense, I had the brush hog set real high or it would bog down during the cutting. But even with it real high, it would occasionally start to bog at which time I would engage the clutch, l would wait for the rpm's to get back to normal, and then continue cutting.
Any idea on the warning light??
   / warning symbol on dash - 1735m #2
Call your dealer about it if you can't find any information in the owner's manual.
   / warning symbol on dash - 1735m #3
Yeah, first what does the manual say that means ?
   / warning symbol on dash - 1735m #4
I had a similar problem. Pull the cover where your fuel filter is (right side of tractor next to step). I had a kinked fuel line.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
Light Tower (A52377)
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
