warning symbol on dash - 1735m
   / warning symbol on dash - 1735m #1
pattycake
Usa
MF 1735m
1725m
37 hours
I was brush-hogging a large dense field yesterday, almost 98 degrees outside, and a symbol ! in a triangle appeared on the dash. Just above the hour display, showed a 1 (one).
When it happened, the rpm immediately dropped. I stopped, shut the brush hog down, and lowered the throttle.... no change. Raising the throttle had no effect. I waited about 20 seconds then turned the engine off. After I turned it back on 10-15 seconds later, the symbol was gone and I was able to increase the throttle like normal. I headed back to the barn and parked it.
When this happened, the temperature showed 3 bars - pretty much what it always shows.
The field was very tall and very dense, I had the brush hog set real high or it would bog down during the cutting. But even with it real high, it would occasionally start to bog at which time I would engage the clutch, l would wait for the rpm's to get back to normal, and then continue cutting.
Any idea on the warning light??
   / warning symbol on dash - 1735m #2
Call your dealer about it if you can't find any information in the owner's manual.
   / warning symbol on dash - 1735m #3
Yeah, first what does the manual say that means ?
   / warning symbol on dash - 1735m #4
I had a similar problem. Pull the cover where your fuel filter is (right side of tractor next to step). I had a kinked fuel line.
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
