GC17xx, coolant change
   / GC17xx, coolant change
Guys, reading the manual, mine says the drain tube drains both radiator and block, so I'm curious why people here are advocating draining the block separately. Is it to squeeze every last bit of coolant that be stuck in the recesses of the block? If that's the case, ain't it kinda overkill?
I did mine yesterday, I didn't unscrew the plug on the block. I just drained via the tube, then flushed with distilled water, ran that a bit, drained again, and filled it all up with new coolant. Obviously did the overflow reservoir as well.
   / GC17xx, coolant change #32
If you are changing it on a regular basis, any residual amount is diluted. So, it's no big deal.
Changing coolant every two years, for most people is overkill.
Sometimes the "feel good" factor is worth it to people.
   / GC17xx, coolant change #33
Distilled water would be the best
Why? Distilled or deionized water is unnecessary in your radiator. Once you ad coolant, your adding various solubles to the cooling system in order to keep the metals in your engine happy. Flush with a garden hose and ad the appropriate coolant mixture. If you have extremely hard water, you might want to use store bought water but only in extreme cases.
2003 PETERBUILT PB330 DUMP TRUCK (A57192)
2003 PETERBUILT...
UNUSED SET OF FUTURE 25', 4 GARAGE JUMPER CABLES (A57192)
UNUSED SET OF...
2013 Freightliner M2 106 Altec AA755 55ft Bucket Truck (A55852)
2013 Freightliner...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
CASE 5200 Grain Drill (A53317)
CASE 5200 Grain...
