AZEK decking verses TREX decking
   / AZEK decking verses TREX decking #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I am going to replace my 10x20 wood deck next spring.I am currently looking at Trex & Azek decking as my options.Any & all opinions are welcome.Thank you.
   / AZEK decking verses TREX decking #2
When we recovered our deck 12 years ago we went with Fiberon decking from 84 Lumber. It was less expensive than TREX, easy to install, and has been extremely durable and very low/almost zero maintenance.
Frank
   / AZEK decking verses TREX decking #3
Is 84 Lumber still in business?
Frank
Any sun fading issues as our deck will have a southwest sun exposer ?
   / AZEK decking verses TREX decking #7
They are probably both very good. I have Azek and it's done quite well for about 8 years now. I pressure wash a couple of times a year and spot clean any stained areas (grease, mold, tree sap). The hidden fastener systems looks good and is reliable. I have a combination of light and dark tones and fading is minimal at this time.
The negatives are heat buildup in the sun and being slippery with snow and frost, but I think that's going to be the case wiht any composite.
   / AZEK decking verses TREX decking #8
Mine has a full southern exposure here in MD and we’ve seen very little fade in the last 12 years. About the only thing I’ve done to it has been an occasional pressure wash.
   / AZEK decking verses TREX decking #9
If you get lots of heat.... look at aluminum decking. I used nexdeck aluminum. Non slip, stays cool in summer. Powder costed. 42E1C7BA-0C34-4F2C-BFF9-C24377424E35.jpeg. I was going to use trex till i talked to a few locals here that had it. They all complained about super hot in summer and slippery in winter. Also some buckling issues.
   / AZEK decking verses TREX decking #10
I'm not aware of any Azek product intended for decking. Azek and Trex are 2 different products intended to be used in different ways. Azek is a PVC board (same as the PVC pipe) it works well as mouldings, and trim and does not need to be painted even in exterior applications. I have it on my cabin and really like it in it's use as trim. It's easy to clean, except where a cut is made and left exposed. When a cut is made a lot of little cells (like honeycomb) are exposed and will collect dirt and be difficult to clean. Those need to be sealed - one way is to use paint another is to sand and then wipe with Acetone, but I've not be especially satisfied with those results. It is not self supporting so spans are limited.
From the Azek website: The Most Trusted Name in Trim, Moulding and Fastening | AZEK Exteriors
Can AZEKョ Trim be used in structural application?
No, AZEK Trim cannot be used in structural applications. WARNING: AZEK Trim products cannot be used in any stress or structural applications. AZEK Trim products can only be used as the decorative part of your application; either wood or metal structural components need to be incorporated for structural applications. Check with your architect or builder if your application is structural.
1993 PETERBILT 362 SLEEPER (A54607)
1993 PETERBILT 362...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
