Choosing just one grease..
   / Choosing just one grease.. #51
I do not understand your post. My data shows the Lucas green tube X-tra HD grease meets the shear stable criteria and should be compatible with almost any other grease. Am I incorrect?
Thanks,
Grey area, ie I am not sure. Tech data sheet says "Polyurea" in the thicknener type. Note the large differences in compatibility (table) between "polyurea" and "polyurea shear stable" thickener. Without a blurb from Lucas confirming it is shear stable I would take the conservative approach.
   / Choosing just one grease.. #53
We have Walmart, didn't check there. $10 seems to be about the going rate for Lucas green in these parts... for whatever reason.
Give Walmart a try, I think it値l be $5-$6 (USD) there. They probably buy a ship load of products from Lucas and get big discounts. I also see Lucas green in other stores priced quite a bit higher.
BTW- love your avatar picture. Great movie. One of the funniest ever.
   / Choosing just one grease.. #54
Complicated charts and grafs dont do it for me, I like seeing real test where the rubber meets the road......... Is Cheap Grease better than Lucas Red N Tacky? Let's find out! Bearing Grease Test Episode 1 - YouTube
They compared a grease costing less 1/2 the price. Super Tech brand also has a more expensive extreme pressure high temp multi purpose grease. One problem with store brand names is they are contracted out and what you buy today might be a different manufacture tomorrow.
   / Choosing just one grease.. #55
That's $10 canadian I take it, what's that in US $, currently? I got a 10-pack on amazon for $50, they still have that pricing on there.
   / Choosing just one grease.. #57
If I wanted to do this, I'd probably go with white lithium, but I'm not sure you can get it in the tubes that go into grease guns.
Ralph
   / Choosing just one grease.. #58
I usually buy grease from TSC. I've never looked on the website though. TSC and most places around here have limited offerings to choose from (I really hate making a special trip to buy something like grease). What I find is funny is that TSC has Rotella grease for $3.99 a tube and a 'price break' if you buy 3 it's $15. Not sure who came up with that. Their travlers brand by the 10 pack is a good deal but you must make sure the person at the cash register knows it. Otherwise they will charge you the per tube price (for example $3.29 for the Traveler's premium HD grease per tube vs $20 for a box of ten). Often they want to open the box and scan one tube and then change the quantity to 10 which doesn't seam to discount it.
   / Choosing just one grease.. #59
That’s crazy, Al :laughing:
   / Choosing just one grease.. #60
Amsoil has a general purpose grease that will work well on anything you own. I've been using it for 25 yrs. Hope this helps.
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
John Deere 4052M (A53317)
John Deere 4052M...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
UNUSED FUTURE X.HW672 72" HYD HOLLOW WOOD GRABBER (A57193)
UNUSED FUTURE...
