Bx2380 hydraulic hose rubbing mmm belt
   / Bx2380 hydraulic hose rubbing mmm belt #1
eubie5
Gold Member
Greenville Indiana (southern Indiana)
kubota bx2380
Just like the title says, my mower belt has rubbed a spot on these 2 hoses. Obviously, it would only happen when I'm mowing with the deck all the way up, which is rare.
But, it does happen.
I bought this new last year. My bx1800 that I had for almost 18 years never had this issue.
I'm assuming I can just zip tie them a little tighter, but I was messing with it this afternoon, and they don't have much play, they're pretty tight.
Is this just a goof from the factory?
Anyone else have to deal with this?
What's the best way to remedy this?
   / Bx2380 hydraulic hose rubbing mmm belt #3
I had a similar situation on an older b. If it were me I’d reroute them out of the way. Are they for a third function valve?
   / Bx2380 hydraulic hose rubbing mmm belt #4
On my bx2200 the lines run under the engine in metal tubing and don't come anywhere close to the mower deck.
I do have a 3rd function that the dealer added. Makes sense that's what they are and not from the factory.
   / Bx2380 hydraulic hose rubbing mmm belt #6
My 2380 does not have a 3rd function (or loader) and I don’t have those lines. From what I remember there is not a lot of options in that area for rerouting, is it still under warranty? Might talk to the dealer and see if they’ll make it right.
   / Bx2380 hydraulic hose rubbing mmm belt #7
Wow, no one's ever dealt with this before?
Call your dad. He will bring over a bunch of zip ties and tie up the hoses so they will stop rubbing yet have enough slack as to not bind any moving parts.
That would be kind of hard to do, since he's been in the ground in south Georgia for over a year.
It would also be hard to do since there's absolutely zero extra slack in the hoses.
I guess you forgot you're posting on a tractor forum.
But regardless, you can go **** yourself.
2001 John Deere M665 (A50120)
2001 John Deere...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
New Wolverine Push Blade (A53002)
New Wolverine Push...
