BX2200 Thermostat
   / BX2200 Thermostat #1
terpdog
Member
Marriottsville, Maryland
Kubota BX 2200
I'm getting no reading from the thermostat of the BX2200. I did just replace the Stop Solenoid. I don't see anything that I missed putting back(everything seems to work fine).
Didn't want to go get another thermostat if it's just a wire that I missed but I don't see anything and all the fuses seem fine.
   / BX2200 Thermostat #2
Replacing your thermostat won't give you a reading. The thermostat helps control the temperature of water circulating in the engine but it doesn't indicate anything. You probably mean you're not getting an indication from your temperature gauge. You could have knocked a wire loose from the sending unit while working under the hood. You can start by retracing your path to the stop solenoid and see if you pulled something loose.
   / BX2200 Thermostat #3
+1.................
   / BX2200 Thermostat
Yes, I just had to be more patient tracing the wires. One wire that was near the front, by the stop solenoid was it. Of course I didn't find this until I pulled quite a few things off.... because.. of course I put those back on. :)
19010 (A55851)
19010 (A55851)
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1EF7EKF89312 (A57453)
2014 Ford F-150...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
