ford 755 backhoe attachment lever bushing
   / ford 755 backhoe attachment lever bushing #1
onekiwi
ford 4500
Hi All I am redoing the lever bushings on the new to me backhoe.The lever bushings are plastic 1/2 " id 5/8" od and about an 1 1/2 long
What does everyone here use...I could buy some 5/8 round and drill them out but there has to be an easier way
Thanks
Carl
   / ford 755 backhoe attachment lever bushing #2
Thanks
Carl
Not sure what you want to use for new bushings, but if wanting a plastic, 1/2” CPVC pipe is about as close as you will find cheaply. I have no ideal how it would hold up under your application, but at under $5 for a 10 ft stick of pipe at most any big box store, you would have a long time supply of bushings. One caution which will be minimum in the bushings but big on storage, the pipe is not UV protected.
Painting is an option if the bushing is exposed.
These are the levers that control the backhoe function, so I am thinking nylon or delrin etc.I believe they were nylon new. I found a 5 ft stick of 1/2 " id and 5/8" od, but the shipping was four times the value of the bushing stock!
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
CUTTING TORCH STAND W/HOSES & VALVES (A55745)
CUTTING TORCH...
