Box Blade DIY Hydraulic Retractable Rippers
   / Box Blade DIY Hydraulic Retractable Rippers #11
I am thinking it will work fine also. The linkage already transfers the force to the pin. Now the force will get transfered to the cylinder.
Will cut and weld the actual linkage tomorrow before sunrise when its not 100F heat index like this afternoon.
   / Box Blade DIY Hydraulic Retractable Rippers #14
When in use the scarifiers pull down as the scraper is pulled forward. So I did not consider a latch and have not needed one. I made it like this Cammond scraper.
Working great, now time for some new hoses.
I wasn't actually trying to move dirt in the video, just wanted to show it working, will try to get another video when my camera crew gets off the bus this afternoon :)
Should have done this years ago.
Hoses on.
I rather have made the top bracket one piece but I don't quite have the proper tools so I used what I had and it should work fine. The upper cylinder mount is what was on the swather already, same with the lower but the lower was just right for this application.
   / Box Blade DIY Hydraulic Retractable Rippers #17
My old old gannon has factory hydraulic rippers on it,
they actually rotate from raised to down and forward and there is no mechanical lock on them.
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
