MaineWoodsman
Hi All - tried searching the forum and did not come up with anything that could help me. I have a Kioti CK3510 HST with a KL4010 FEL and I want to install the W. R. Long 3rd function valve. The instructions state there is a steel tube that runs from the power beyond port on the loader valve under the seat, and to remove this tube and attach the diverter valve to this. As there are no pictures I am not sure which tube they are referring too. My tractor has a Kioti branded backhoe that was added at the dealer. It has rear remotes. I am thinking this is different than what the instructions may apply to?
Here is the loader valve as seen from the right rear tire side
Here is the opposite side, showing the hydraulic hose to the rear remotes and they what I believe to be the bypass back to hydraulic fluid tank under that
Finally the remotes block showing in from loader valve and out to rear remotes. There is also an out to what I believe is the bypass back to hydraulic tank, on the side toward the middle of the tractor but not really shown here.
If anyone has a similar setup and can advise me, that would help. Bonus for pictures of your installation. I want to use my EA grapple badly!
