Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #14,841
Thanks.
That pic of the Chevy p/u with the log load; is that yours?
It is not, just something I found online.
Probably not even real.
   / Tractors and wood! Show your pics #14,842
For fire starter I simply fill a 5 gallon bucket with planer chips and pour in pint or so of diesel fuel. Put a lid on the bucket and in a short while the chips will absorb the fuel making a non explosive fire starter..
A small scoop will get a good fire started in no time. Been using that method for 40 years.
That seems like a better option but not many have planer chips. Wonder if it would work with sawdust?
The left-overs from "noodling" a log (cutting parallel to the grain with a chainsaw to split a log) make a great fire starter. The dry quickly, and once dry you don;t need to soak them in anything just throw in a handful or two and light it.
Sawdust often packs too densely to burn well, but maybe when soaks with something it would work?
   / Tractors and wood! Show your pics #14,843
After searching for 2 years, I finally found a used logging winch in decent shape for reasonable money.
A guy in the next town over posted it 3 days ago and I jumped right on it.
Hooking up was helped by the 3ph telescoping lower arms.
Norse 450. Good size for the 6040.
As Oldpath mentioned, adding a hitch to pull a trailer can be handy. You can usually find a way to add one, but the method varies from brand to brand. My Uniforest 35E did not come with a hitch, but I noticed that a bolt-on hitch was included with their larger models. The channel to which they bolted was on my model, so all I needed to do was order the hitch and drill the holes in the channel that ran down the center of my which frame. (sorry, no picture of this one mounted)
I later decided I did not like the pin hitch. It did not allow enough flex when driving through ditches and waterbars, so I had a local fab shop use the factory hitch as a pattern, and make me a receiver hitch that mounted the same way. I ended up pinning it on, rather than bolting. It tends to rattle more now when going over bumps, but I can put it on and off in seconds, without any tools. I had this receiver tube made short, to reduce the cantilevered loads hanging off the back of the winch (not an issue when pulling my log splitter, but the tongue weight on my firewood trailer can get heavy at times). The short tube requires shortening my receiver inserts and redrilling the hole for the hitch pin, but those same inserts also fit the shortened receiver I had made for my Coot (an antique UTV I sometimes use for firewood or splitter hauling). Show here with an insert to use with a pin hitch, since one of my firewood trailers is set up that way.
I've seen pictures on here where people found a spot in their butt plate where they could safely cut a hole and weld in a receiver tube. This is nice because you don't have to have a lot of "hardware" hanging off the back of the winch, just a bit of receiver tube poking out. (I remove my receiver when doing a lot of winching or skidding, so I don't end up beating it up with the logs.) welding in a receiver tube was not an option for me, due to the center rib. I would have had to make the hole way off-center due to the rib and the location of the "works" on the other side of the butt plate.
If cutting a hole and welding in a tube is not possible on your winch, you could always weld some tabs or a piece of channel on and do something like mine.
   / Tractors and wood! Show your pics #14,844
John_Mc - I had not thought about a hitch but now you have me thinking about one.
The Norse butt plate is flat so I suppose that would be a likely spot.
   / Tractors and wood! Show your pics #14,845
Anybody want a toothpick?
attachment.php
attachment.php
   / Tractors and wood! Show your pics #14,849
I bet his little tractor doesn't think so.
Handled it a lot better than I thought it would. Wood calculator figured around 800 pounds. Just wish I'd centered the weight a little better but I wasn't really expecting it to lift it at first and figured I'd need to readjust. Once up, I didn't want to mess with it again. I only traveled a couple of hundred feet and kept it low and slow.
   / Tractors and wood! Show your pics #14,850
Low and slow is good if you have a big *** log in (on) your bucket!!
I Wish I had your little backhoe though!!
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light (A52377)
2019 Allmand Bros...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
