Any recommendations for LED floodlight/security light to hang on garage?
   / Any recommendations for LED floodlight/security light to hang on garage? #11
Really happy with our ring floodlight cams. They have a panic alarm you can activate. I've ran off 5 or 6 people at our business that showed up after hours that seemed to be up to no good.
Sounds great, but won't work for me and many other rural folks. My internet speed is not fast enough. My CenturyLink dsl upload speed is too slow.
   / Any recommendations for LED floodlight/security light to hang on garage? #12
I have 2 of these overlooking about an acre and a half field. It covers almost 80% of the field.
On my building I have a rectangle dusk to dawn light. I bought it at Lowes Hardware. I tried to find a pic of it but it seems to work great also
   / Any recommendations for LED floodlight/security light to hang on garage? #13
Our service averages about 8 to 10 mbps. Wouldn't want them on anything slower.
   / Any recommendations for LED floodlight/security light to hang on garage? #14
   / Any recommendations for LED floodlight/security light to hang on garage? #15
After dealing with cheap ones when changing mine over from incandescent, I finally broke down and started buying RAB lights. Amazingly well made.
RAB STL3FFLED18 18W LED Security Light, 360 Motion Sensor, 5000K (Cool), 120V, Bronze, Hardwired, Multi https://www.amazon.com/dp/B00AZVZ98M/ref=cm_sw_r_cp_api_i_JPRtFbGNRK509
Not cheap, but if you watch Amazon they can be had around $160.
   / Any recommendations for LED floodlight/security light to hang on garage? #16
I've been taking the high pressure sodium outdoor lighting and convert to simple screw in LED bulbs. Remove transformer and wire directly to photo eye. Make sure the fixture has the same common E26 light bulb base. You can put whatever watt LED bulb you want in them and replacement is inexpensive. Got several fixtures from Home Depot 75% off. Fixtures are heavy duty.
   / Any recommendations for LED floodlight/security light to hang on garage? #17
I installed an old school style wall-pack light over my rollup shop door. It is LED and has dusk/dawn sensor but I also installed a standard wall switch if I do not want it coming on every evening. Unobtrusive simple design. No regrets.
   / Any recommendations for LED floodlight/security light to hang on garage? #18
   / Any recommendations for LED floodlight/security light to hang on garage? #20
I have a couple of solar charged, motion sensor LED lights that work great. They each have three pods similar to the Amazon link above. They have been going for 3 or 4 years. A 110 volt sensor light on my workshop failed after about 5 or 6 years. Thinking of replacing it with one similar to the other two.
PENDING SELLER CONFIRMATIONS (A54313)
PENDING SELLER...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
1999-2010 Ford Pickup Truck Bed (A52377)
1999-2010 Ford...
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2019 CATERPILLAR...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
