Bolts loose - why?
   / Bolts loose - why? #11
I NEVER had "kinda loose" bolts on my NH TC33D. I had a nut on the hydro pedal linkage come loose after 350 hours....that's it. But of course, the dealer gave me a good trade in value for it saying "they don't make them like that anymore".
   / Bolts loose - why? #12
If anything I would blame the dealer, not the tractor brand. While LS does seem to make some pretty darned good tractors, most of what you describe could be attributed to sloppy assembly after shipping.
If the local LS dealer is representative of their distribution base, that could be the weak link in the system.
I know that he's why I wouldn't consider an LS... I dealt with him- once- when he was a transmission repair shyster- er, repairman. My friend's on bought a Montana from him when he became a dealer... watching that unfold was strikes 2, 3, and out.
   / Bolts loose - why? #13
Has anyone mentioned that theres a torque spec for dry and lubricated fasteners? Some vehicle manufacturers specify that lug nuts never be lubricated otherwise you risk having them vibrate loose.
   / Bolts loose - why? #14
With some 1,050 hrs that I've put on my B7800 (it's got 1,800 hrs on it now) I only found one loose bolt and I believe it was one of the ones on the loader cross bar. I'm not sure a person could work a machine harder than I've worked the B7800.
I had a bolt that holds a pin in the lower link arms on my NX5510 disappear on me, which resulted in the pin popping out (fortunately it fell and stayed on the top of the draw bar plate) and the arm dangling (was getting frustrated that the brush hog seemed to be digging in and I could't correct it!). Wasn't quite catastrophic, but it could have been. I locktite'd the new bolt and the one on the other side: I also informed the dealer; recommended that they do the same.
Lots of assembly takes place at the dealer's. Likely lots of things that people find loose can be blamed on their dealer.
   / Bolts loose - why? #15
My experience has been once torqued to the proper spec, the fasteners will stabilize after a couple of retorques. Having said that, good practice to recheck during normal service intervals.
My experience also. Wheel bolts fastening two part wheel rims are particularly prone to loosening during first 100 hours of operation.
Knobby tread tractor tires produce a lot of wheel vibration when running on hard surfaces.
I would blame the dealer, not the tractor brand. Most of what you describe could be attributed to sloppy assembly after shipping.
Yes. All the Backhoe fasteners should have been torqued to spec at the dealer.
   / Bolts loose - why? #16
I found lots of loose bolts on wheels and loader frame up until the first 100 hours. Check at 10, check at 50 and check at 100 for sure. Then check at the 400 service interval where you change all the fluids. I haven't seen any loosen up since 100, but still good idea to check. I don't see anything unusual at all with having loose bolts at the 10 hour check. You did good to check. I think paint compression may be part of the problem in new units. In any case, checking bolts is always a good idea.
   / Bolts loose - why? #17
That is one issue with any piece of equipment,
it is usually assembled by the lowest paid greenest hand many times without adequate instruction.
And I would doubt that they had or used a torque wrench or even torque sticks.
That happened to me on my third Kubota purchase. The 2009 (B2660), the 2012 (B2620) were fine..........but the 2018 (B2650) not only had many loose bolts right after delivery.........but had several totally missing. The dealer fired that hand and ultimately the service manager.
But now, the ball is in my park.....i.e. do some torque checking soon!!
Cheers,
Mike.
   / Bolts loose - why? #18
Bolt should not loosen by them selves, with correct torque and proper engineering.
Don't see people running around big 50t wheel loaders retorque bolts and nuts. Do you check all bolts on your car several times a year? Why does loader brackets get loose?
This is why cars of yesteryear often used Castilated Nuts with cotter pins...
Present day restorers find Locktite Blue most helpful...
   / Bolts loose - why? #19
I used to put NeverSieze on my pickup log nuts, until I found out that it can be a bane as well as a benefit.
   / Bolts loose - why? #20
I use never-seize on all of lug nuts and most all threaded fasteners on every thing that I work on.
When someone else does something tothem I can hear the muttering a they come away all silver,
but it unbolts nicely even up here in the super rust belt.
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
Terms and Conditions (A47477)
Terms and...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
