JD hay rake #594
   / JD hay rake #594 #1
mp7959
Yanmar FX17D
Does anybody have the parts manual for this vintage of hay rakes?
   / JD hay rake #594 #3
   / JD hay rake #594 #5
Welcome to TBN
beenthere is correct JD didn't manufacture a rake with model # 549 but did manufacture a rake with model 594. JD parts catalog # for a model 594 rake is PC238.
   / JD hay rake #594 #6
That is older than dirt....:)
Now Easy on the older than dirt as that rake could only be 10 yrs older than ME:dance1:
   / JD hay rake #594
Hi
Thanks for the response's, yes it probably is the #594 model (I must have wrote 549 after one too many trips to the shed where the Fireball storage locker is located). Yes it is part #11 in the JDparts manual link that 'beenthere' shows, however it does not give the actual part # that I would need to order another one. I've contacted several bearing supply companies on-line and they do not have a match for the dimensions of this cylindrical roller bearing without a inner or outer race unlike most shaft bearings .
See attached pic (width/ 'C' = 2-3/4", I.D/ 'A' = 1-5/8", O.D/ 'B' = 2-1/2")
  • Bearing pic.pdf
   / JD hay rake #594 #8
mp7959
I replied to a similar post on another discussion forum & stated the brg part # AL66E is available from ""Parts Dept"" but to get parts from them one must utilize a participating equipment dealer. IIRC Parts Dept had 4 AL66E brgs.
   / JD hay rake #594 #10
Hi
mp
Try to edit the subject line of your thread to reflect the correct model number.. think you can within a certain time limit. Will help the TBN archives for future members.
Also, inspect the parts that go through the bearing and that contain the bearing to see if a machinist could bore and machine those parts to fit one or two new bearings.
If in question, post pics of the two parts involved.
There are several threads on TBN pertaining to the model 594. Might be interesting to you to read through them.
2025 Spirit 48 48V 1000W All Terrain Electric bicycle (A55758)
2025 Spirit 48 48V...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
2019 Cat D6N LGP Dozer (RIDE AND DRIVE) (A50775)
2019 Cat D6N LGP...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
CAT 966 (A53314)
CAT 966 (A53314)
2012 Jaguar XJ Sedan (A55758)
2012 Jaguar XJ...
