TODAYS SEAT TIME
   / TODAYS SEAT TIME #11,661
Most of it concerns the load on the engine,
the less engine hp for the same load the more the governor has to open up (throttle)
to maintain the engine speed.
A 30 hp unit running a full 30 hp load is likely to use as much or even more fuel then a 60 hp unit
on that same 30 hp load and just loafing along with the governor just above the no load rpm setting.
Yep, Big Engine Working Easy Better Than Little Engine Working Hard.
   / TODAYS SEAT TIME #11,663
Molalla is probably pretty bad, most of that area is evacuated, Tuesday was pretty dark, the rest of the week has been smokey and gross... I was working outside yesterday in a respirator...
   / TODAYS SEAT TIME #11,664
My tractor has a rain switch. It's the same one I use to start the engine.
   / TODAYS SEAT TIME #11,665
Had a conversation with a co-worker years ago. He was yapping about how much power is being derived from small engines. Example of 800 hp from a 2 liter race engine. I simply said - if small engines are so powerful, why don't they put them in big trucks? The answer was mumble, blubber, can't reason with you. Pretty funny.
   / TODAYS SEAT TIME #11,666
Well for starters they rev so high they’d require ridiculous gearing to work. The second bigger problem is big trucks are designed for multiple million mile service. Little engines making big power don’t last long.
   / TODAYS SEAT TIME #11,667
Oh - not good. Thanks for the info ranger
gg
   / TODAYS SEAT TIME #11,668
How are things out your way fire/smoke wise Molalla1 ?? The daughter in SW Portland is in pretty heavy smoke. Her work place is shut down.
gg
I am not suppose to be here now evac was 4 days ago, but most of us stayed . . . fire is about 5 miles from us but I have a good fire brake behind us cut with my D4 and freshly cut pasture behind that . . . a neighbor has a 1000 gal. mobile unit and has gone to the front and helped . . . but so far so good Gordon :thumbsup:
edit . . . the smoke and ash is nasty, even Portland (40 miles away) is heavy in the same . . . the west coast is burning .
   / TODAYS SEAT TIME #11,669
I hope you folks are monitoring 24/7 and someone doesn't fall asleep on fire watch! :whistleblower: Stay safe!
   / TODAYS SEAT TIME #11,670
Stay safe Brother. Y'all are in our prayers. Maybe some rain up there next week.
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
1268 (A50490)
1268 (A50490)
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
