G1800 48" center blade cuts lower than outer blades
   / G1800 48" center blade cuts lower than outer blades #1
bstauss
Kubota G1800
Just acquired a G1800 with 48" mower deck. The center blade cuts lower than the outer two blades. I measured the blade height under the deck and the center blade is 5/8" lower than the outer blades. It does not appear to be installed incorrectly. The mower deck is way out of whack adjustment wise, and I've been tinkering with that. But with the deck on the ground, center is clearly lower. Any thoughts on way? The blade does not appear to be bent. Thanks!
   / G1800 48" center blade cuts lower than outer blades #2
First thought is to check that all 3 blades are the same. Some mowers use flat blades, others use stepped blades (blade edge is lower than center). If they are all the same, check the spindle depth, and make sure the spindles are the same. Has to be one or the other, unless the deck itself is really damaged
   / G1800 48" center blade cuts lower than outer blades #3
Loosen or take belt off : turn blade tips together & see how far they are off.
Both sides of each blade in any combination is supposed to be dead level.
Buy a new set of blades & check this same procedure.
I’ve seen new mowers with uneven spindles from the factory.
Too many shims or spacers between the two bearings will lower or raise the spindle shaft making new blades uneven.
You’ve got to start with new unused blades before making any adjustments.
   / G1800 48" center blade cuts lower than outer blades #4
Some of those older, smaller Kubota decks use different blades in different positions.
   / G1800 48" center blade cuts lower than outer blades #5
same thought process as Brown Dog above - spindle may have been replaced at some point and wasn’t seated properly when installed
Thanks for the suggestions guys. I have another G1800 with same 48" deck and it is the same way - center blade on this one is also 5/8" lower. The Messick's parts diagram shows the same part number for all three blades. If I rotate the blades to where the tips touch/cross, they are all the same height. It's the "north/south" orientation when it is off 5/8". That suggests both decks have a center spindle that is bent forward - what are the odds of that? The previous owner gave me two extra sets of blades (now new, but not visibly damaged or bent), and installing those, no change. I do know one of these tractors was used in a lawn care service (the one with 1100 hours), so it's possible a spindle was replaced and incorrectly. The other one, with 800 hours, was only used to "mow Mama's 6 acres". Guess I need to pull one of the decks and do a closer inspection on the spindle.
   / G1800 48" center blade cuts lower than outer blades #7
Have you checked all 3 shafts for up & down loose motion with belts off ??
I don’t see how North & South problem could happen unless deck flange is bent where spindle bolts to it.
I’d still buy a brand new set of blades, install & start all over with your checks IF you don’t find any up & down loose motion in your shafts.
   / G1800 48" center blade cuts lower than outer blades #8
I had a New Land Pride Spindle cutting 1/2” lower than the other two.
No loose motion, brand new blades.
Nothing at all wrong.
I used washers between the deck & spindle housing to raise it the 1/2” & it’s been flawless for many years.
5/8” is a LOT BUT it can be fixed.
May have to disassemble a spindle assembly
   / G1800 48" center blade cuts lower than outer blades #9
Built in lawn striping?
I have a 54" JD deck that is all out of whack. It looked like new so it probably got pulled off a mower under warranty. Unfortunately I didn't find it until I spent many hours adapting it to my F725 mower. I think I can build a fabricated deck easier than I could figure a fix for it.
   / G1800 48" center blade cuts lower than outer blades #10
Exactly, it has to be a bent deck shell. New blades are not gonna help. Take the blades off and stack them, if none are bent they will nest perfectly and the blades are good to go.
2021 Toyota Corolla LE Sedan (A50324)
2021 Toyota...
Wolverine Mini Skid Steer Auger Drive & Bit (A50515)
Wolverine Mini...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
