Metric seal/oring sources for jinma 254 lift cylinders ?
   / Metric seal/oring sources for jinma 254 lift cylinders ? #1
Arizona
2004 Workhorse 2840
Does anyone have a couple of metric seal sources for our hydraulic cylinders?
So far the measurements of the 2 gland nut seals are 28 x 37 x 7 and 28 x 37 x 5. 37 mm is not as easy to find as 36 and 38 mm.
Individual or kit form is fine.
Thanks !!
   / Metric seal/oring sources for jinma 254 lift cylinders ? #2
Try Motion Industries. They might be able to help you.
   / Metric seal/oring sources for jinma 254 lift cylinders ? #4
We stock the rebuild kits for the Jinma ZL-20 Front loaders, give us a call there are 2- sizes of Chrome rods 25mm and 28 mm , you said you have the 28mm
ZL-20 cylinder rebuild kit
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
979-865-4002
Hi Tommy,
Unfortunately I didn't mention that my loader is not a ZL-20. It's something else. Not sure of the brand. What is the OD of your rod seal and piston seal ? They need to be around 37 or 38 mm od.
Hi Pedro,
I saw you have a Youtube channel.
No joy for Motion Indistries.
We have a Place here called Martian Fluid Power, they can get you anything you need, they make some also
Tommy
979-8765-4002
Score !! Thanks Tommy. They had every item to rebuild both arm cylinders on my 254a tractor. Plus I bought spares.
Here are the part numbers if anyone needs them.
https://www.mfpseals.com/cart/view 248-585-8170 900 E. Whitcomb Ave. Madison Heights, MI 48071 Ask for Stephanie.
MSUC-028X038X05.0 MSUC METRIC U-CUP METRIC URETHANE $3.25
MDRW-028X036.6X05.3 MDRW ROD WIPER METRIC U2145 (Ultraflex) $1.87
MWRP-050X10.0X2.5 MWRP WEAR RING METRIC PHENOLIC $3.23
MOR-1.9X006.4BN70 O-RINGS METRIC BN70 NBR (Nitrile) Qty 16 for $2.00
MOR-3.5X043.7BN90 O-RINGS METRIC BN90 NBR (Nitrile) Forgot the price.
For orders under $50 a handling fee of $4.95 is charged. $25 minimum order.
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
1263 (A50490)
1263 (A50490)
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
