Metric seal/oring sources for jinma 254 lift cylinders ?
   / Metric seal/oring sources for jinma 254 lift cylinders ? #1
Arizona
2004 Workhorse 2840
Does anyone have a couple of metric seal sources for our hydraulic cylinders?
So far the measurements of the 2 gland nut seals are 28 x 37 x 7 and 28 x 37 x 5. 37 mm is not as easy to find as 36 and 38 mm.
Individual or kit form is fine.
Thanks !!
   / Metric seal/oring sources for jinma 254 lift cylinders ? #2
Try Motion Industries. They might be able to help you.
   / Metric seal/oring sources for jinma 254 lift cylinders ? #4
We stock the rebuild kits for the Jinma ZL-20 Front loaders, give us a call there are 2- sizes of Chrome rods 25mm and 28 mm , you said you have the 28mm
ZL-20 cylinder rebuild kit
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
979-865-4002
Hi Tommy,
Unfortunately I didn't mention that my loader is not a ZL-20. It's something else. Not sure of the brand. What is the OD of your rod seal and piston seal ? They need to be around 37 or 38 mm od.
Hi Pedro,
I saw you have a Youtube channel.
No joy for Motion Indistries.
We have a Place here called Martian Fluid Power, they can get you anything you need, they make some also
Tommy
979-8765-4002
Score !! Thanks Tommy. They had every item to rebuild both arm cylinders on my 254a tractor. Plus I bought spares.
Here are the part numbers if anyone needs them.
https://www.mfpseals.com/cart/view 248-585-8170 900 E. Whitcomb Ave. Madison Heights, MI 48071 Ask for Stephanie.
MSUC-028X038X05.0 MSUC METRIC U-CUP METRIC URETHANE $3.25
MDRW-028X036.6X05.3 MDRW ROD WIPER METRIC U2145 (Ultraflex) $1.87
MWRP-050X10.0X2.5 MWRP WEAR RING METRIC PHENOLIC $3.23
MOR-1.9X006.4BN70 O-RINGS METRIC BN70 NBR (Nitrile) Qty 16 for $2.00
MOR-3.5X043.7BN90 O-RINGS METRIC BN90 NBR (Nitrile) Forgot the price.
For orders under $50 a handling fee of $4.95 is charged. $25 minimum order.
JOHN DEERE 460M LOT NUMBER 258 (A53084)
JOHN DEERE 460M...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
John Deere 6120E (A50323)
John Deere 6120E...
JOHN DEERE 7R210 LOT NUMBER 49 (A53084)
JOHN DEERE 7R210...
