BukitCase
Elite Member
- Joined
- Feb 17, 2012
- Messages
- 2,756
- Location
- Albany OR
- Tractor
- Case 580B, Long 460, Allis-Chalmers 160
I have a good example of a fixed displacement pump laying under a workbench in pieces - got in a hurry plumbing in a hydraulic drive sickle bar cutter, forgot that the first pressure relief on a 580B is part of the loader valve. Hooked the cutter up AHEAD of the loader valve - encountered a bit tougher limb than the cutter liked and it stalled out - heard a bang, made an oily spot on the ground, discovered the center section of the gear pump was in 2 halves...
But you're right, fans act a LOT different than fixed displacement pumps - up to the point where the ducting a fan is blowing thru allows more air than the fan's open CFM rating, a larger duct will let more air (CFM) thru. The air VELOCITY would likely be faster thru the smaller piping, but NOT enough to maintain CFM (IIRC)
Ignoring the flow resistance of whatever ducting/piping due to friction/air drag, the cross-sectional area of the duct will (more or less) decide the flow. Staying below the fan's CFM ability, the CFM will closely follow the cross section of the duct (ratio wise)
With a fixed/positive displacement pump, if you start shrinking the plumbing you better do it with stronger piping or add a relief valve, or SOMETHING's gonna go pop...
In Gene's case, staying with the 6" ductwork will flow more air than 4, with a LOWER VELOCITY - perfect for NOT sucking all the shielding gas away from the weld... Steve
