Dump Trailer with scissor lift and ATV WInch
   / Dump Trailer with scissor lift and ATV WInch #1
comeaump
Digby, NS
Kioti DK35
I have been looking at his site for many years and have learned a lot from it. Thought it was time to share a project I built. The original concept came from a couple YouTube videos which I watched many times while taking notes. I needed a dump trailer that could be used with the ATV and Tractor as I have two gravel pits and many roads and hills on my 85 acres. It is a bit heavy for an ATV but strong enough for a full load of gravel.
WHEELS: I wanted a walking beam for rough terrain and ease of pulling. I used VW rear axles with 14 in wheels
FRAME: I wanted a frame solid enough to haul full loads of gravel. ( bit too heavy for my ATV but works)
BODY: A bit heavy with 2x2 square tubing but hasn't bent any yet.
Trying on the body to see how it will fit:
BODY LINNING: I used the steel from a 200 gallon oil tank.
Adding some paint:
Loading with top soil:
For the dump I used a scissor lift with a 3000lb ATV winch. I haven't had a load in it yet that it wouldn't dump while sitting on the seat. The winch is on a plate so I can take it off when not using. ( one bolt holds it in place) I also use the same winch on my log arch. There is a pulley at the top of the post and on the front of the dump body. The cable does the lifting at first than the scissor lift brings it to a steep angle to dump all the load ( sorry I don't have a picture of it ) Both tail gates open left or right or fold down.
I have studied a lot of different trailers with the winch / scissor lift concept and many didn't work and gave up. After trial and error mine works perfect.
   / Dump Trailer with scissor lift and ATV WInch #2
Nice !
   / Dump Trailer with scissor lift and ATV WInch #3
Nice to have you here with us comeaump. Thanks for showing your trailer project. I used a UTV dump trailer for a summer and wore the walking beam suspension out. Yours must be better.
it is built heavy enough should last a long time. I used DOM tube and shaft for the hinges. Runs a lot smoother than my ATV at fast speed
   / Dump Trailer with scissor lift and ATV WInch #5
When this manufactured trailer walking beam wore out, we replaced it with dom tubing as well. Put grease zerks in it at the same time. Your looks much better than what that manufacturer did.
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
35176 (A53424)
35176 (A53424)
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
