Buying Advice New or Used. 2020 CK1026 or 2015 CK30
   / New or Used. 2020 CK1026 or 2015 CK30 #1
jrsue
Member
Ventrac John Deere1025R Kioti CK2610
Edit..Title is wrong CK 2610 not 1026
The New CK 2610 HST with loader is $20000 out the door. Vs. I found a 260 hr 2015 CK 30 Hydrostat with loader $16000. I guess the CK 30 has tier 3 which I don't understand, but he says it doesn't have all the EPA garbage on it. I could get my grapple and a back blade and still be under $20000. But the the CK2610 is brand new with warrenty . So any thoughts?
   / New or Used. 2020 CK1026 or 2015 CK30 #2
The New CK 1026 HST with loader is $20000 out the door. Vs. I found a 260 hr 2015 CK 30 Hydrostat with loader $16000. I guess the CK 30 has tier 3 which I don't understand, but he says it doesn't have all the EPA garbage on it. I could get my grapple and a back blade and still be under $20000. But the the CK1026 is brand new with warrenty . So any thoughts?
CK 30.......ABSOLUTELY!!!
In 99% of cases, the warranty on a new tractor is never used, but with the CK1026, you would get Tier IV for free....WORSE than worthless!
Please add your general location to your profile.
   / New or Used. 2020 CK1026 or 2015 CK30 #3
Do you mean a Kioti CK2610?!? Never heard of a 1026.
Some folks, like fried here, are terrified of the new tier4 emissions motors. But the vast majority of them operate fine without issue. And you get a quieter, cleaner running tractor that doesn't stink up your barn/garage when you fire it up.
Can you also get 6-yr, 0% financing on the new Kioti? That would affect my decision making also.
Yes it's the CK2610 HST. Yes sir 0% for 7 yrs.
   / New or Used. 2020 CK1026 or 2015 CK30 #5
Also, the CK2610 does not have any tier 4 emissions crap.... it is compliant without any regen stuff. I would choose the new CK over the 5 y/o CK30. Do you know the tractor's owner, has it been well taken care of (maintenance, etc..) or is the oil recently changed for the first time? I have heard quite a few stories of apparently "clean" tractors having nothing but troubles. Also a lot that were great deals... you have a hard decision.... good luck.
   / New or Used. 2020 CK1026 or 2015 CK30 #6
Nice. And yeah, duh, the CK2610 is not a tier 4 engine, just a regular old school diesel motor.
The CK2610 has a MUUUuuuch stronger loader (make sure the dealer has it with a new 4030 loader, not the old weaker 2610 loader) than the old CK30. I'd definitely go new for the much greater machine capability, warranty, and financing options.
Thank You, That's where I was leaning and just needed a nudge. Any recomendations on Quick Hitches? I want to get a rake, maybe a box blade, utility box.
   / New or Used. 2020 CK1026 or 2015 CK30 #8
Dunno, I've never used a quick hitch. I only change my rear 3-pt attachments a handful of times per year so don't mind the extra 5 minutes to get the job done, though it can certainly be a pain. BUT, Kioti does offer telescoping lower links as an option for the 3-pt hitch, which I would definitely opt for. Should make hooking attachments a breeze and probably eliminate the need for a rear quick hitch unless you really are changing multiple times per day.
   / New or Used. 2020 CK1026 or 2015 CK30 #9
I just bought a brand new CK3510SE HST last week for 20,995 OTD...you should definitely be able to find a better price on a CK2610
   / New or Used. 2020 CK1026 or 2015 CK30 #10
I would purchase the new machine with warranty.
If you store your implements on dollies, on a cement floor, and have the telescoping arms, changing them over is not that bad. The biggest PITA I have is mounting the inverted blower but that is due to the PTO. Getting the 3PH pins and top link connected is fine and I am 70.
For the cost of a decent QA you are about 50% of the cost of a hydraulic top link (if you have a rear remote standard) and that is far more useful IMHO.
If you decide on the QA, be aware that not all attachments are 100% compatible and many of the older ones are not. They can be made to fit but some work is needed.
20' Inline Feed Bunk (A50515)
20' Inline Feed...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
DRUM OF MISC HOSE CLAMPS (A51244)
DRUM OF MISC HOSE...
UNUSED TOPCAT HDRC HYD QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED TOPCAT HDRC...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2010 Ford F-150 (A50323)
2010 Ford F-150...
