Somebody was trying to take the tracks off on a TB180FR and by accident broke the knob that releases tension on the auto tensioner. He then by accident removed the valve/knob and fluid came spraying out everywhere because he did it with the machine on. When replaced it will tension some when put into high speed mode but tension will not hold when high speed is turned off and it leaks from the valve/knob area. With the machine off I checked the other side by removing the valve and I can see what looks like a (valve piston on a lawnmower engine) behind where the tension valve/knob goes and it looks like it should press against this. The broken side does not appear to have this valve piston however it didn't look like anything came out except fluid. Is it possible it got pulled in? I probably am not making much sense but am at a loss. Is there a way to fix this without replacing the entire auto tensioner cylinder?
