Weak Arc on Lincoln 225 ac
   / Weak Arc on Lincoln 225 ac #71
One way to think of a sine wave is it's like a kid on a swing. Kid at rest it's zero volts. Then the kid swings high as he/she can let's say 8 ft. up. So up 8ft., back to zero (bottom) backwards up to 8ft.
Now you have two kids on a two swing set.
They swing opposite,* so as one kid is at forward top, other is at backward top.
When each kid is at top it's double the 8ft. or they're 16ft. apart.
The swing set frame is neutral...grounded.
Just like household power. 240 volts it's like the kids when they're 16ft. apart...but EACH kid is only going up 8, to ground, then back 8.
The kids are swinging really fast! 60 times a second!
So each kid is a phase...one goes up as other swings back.
If a person had reflexes like a cat, you could hold onto neutral/ground and with other hands finger touch either side hot wire exactly when sine wave is at bottom (SUPER fast) and not get shocked. But...we don't so don't try it.
James (kOua) gave good explanations.
   / Weak Arc on Lincoln 225 ac #72
I'm afraid to even walk across the room now to turn the light switch on.....:eek:
   / Weak Arc on Lincoln 225 ac #74
Yeah... I agree ...Being in the dark seems a lot safer.....
Dale
But if you don't turn the lights on you could trip over something and fall and hurt yourself.
   / Weak Arc on Lincoln 225 ac #75
In the dark one could get kicked by that kid up at 8ft...I mean 170 Volts!
   / Weak Arc on Lincoln 225 ac #76
Im an electrical contractor.....
And im bored of this thread.
2017 Ford Expedition SUV (A56859)
2017 Ford...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
2007 Toyota Camry Sedan (A56859)
2007 Toyota Camry...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
