Mitsubishi MT210D Tractors & Atachments
   / Mitsubishi MT210D Tractors & Atachments #1
Goodtimze
Eastern CT
Kubota L3450
I recently purchased a Mitsubishi MT210D tractor and I am looking for information on what kind of backhoe I can mount to it and any info on locating a used one. I am also looking for any information anyone might have on parts. Specifically I am looking for a pinion shaft for the front axle. Any help would be appreciated.
   / Mitsubishi MT210D Tractors & Atachments #2
Re: Mitsubishi MT210D Tractors & Atachments
Any backhoe larger with more than a 6' dig depth would require a frame mount kit. Used small hoes are not real easy to find. The tractor should have enough GPM pump to operate a 6' hoe. I'm a Mitsubishi dealer & can supply you with parts or new backhoes. Email me for more information.
   / Mitsubishi MT210D Tractors & Atachments #3
Good Evening Sir(s).
I am looking at a Mitsubishi MT210D tractor for sale right now and I'm hoping to get your opinion on the price and some info on possible implements.
Not sure the year, but it's got 1020 hrs. on it, comes with a (4ft.?) roto-tiller and a belly mower. Its for sale for $3000.
Eventually, I would like to equip the tractor with a loader. What would this require? A seperate hydraulic system, and mounting? Would I need to locate Mitsubishi factory parts for additional implements or are there 'universal' parts? I'm very green when it comes to understanding older compacts, so any help and guidance would be greatly appreciated.
John
   / Mitsubishi MT210D Tractors & Atachments #4
I sold my MT210D 10 days ago, after owning it a year. I highly recommend Valley Power for help with parts and advice. My MT210D had 402 hours on it when I sold it, 369 when I bought it. I live in foothills of the Sierra mountains, and have some steep grades and lots of oak trees. The first change I made was to built a ROPS, as the 210D is tall and narrow. According to the dealer, the front end is the weak link, and if it's not maintained will wallow out around the pins and break. He has three in the salvage yard like that. Given that, I would not put a loader on one. YMMV.
Mine was not enough tractor for my terrain. Even with loaded tires and 200lbs of weights in front, it could not pull a 5' rotary cutter up the steeper hills. It would either spin out or overheat. It was great on small grades or flatland. I bought it with a well-worn 4' rotary cutter, a 5' back blade, a 4' disc, and a single plow for $3200. After coming to the realization that a tractor is needed for my property, and I needed a bigger, heavier, more powerful one, I sold the tractor with full disclosure on overheating it, 4' rc, and back blade on Craigslist to a local dealer for $1500 - and he promptly relisted it for $5500. Trade in value was $500.
It was a great introduction to tractors, and would make a great flatland 4WD utility/garden tractor. Call Valley Power Products (Valley Power) and tell him what you want to do with it. He's very knowledgeable, and freely shares his knowledge. He saved my backside a couple of times (don't "tap" a cast iron linkage arm for any reason!) and his manuals reprints are very clear. I bought both the owners and service manuals from him, as well as several parts that were long OOP.
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
