Pot Question
   / Pot Question #1
Damifino
Gold Member
Central Fl.
DK35SE
:laughing: I know guess how many views vrs replies, I have a Delta GR450 bench grinder. I purchased new and liked the variable speed control. 1725 - 3450 rpm.
Went to sharpen some tools and it ran at 3450 or higher, when I try to adjust speed control, no difference.
Took it apart and the pot (potentiometer) fell apart. It's a 3 wire that goes to a black box inside the grinder.
Checked all over online for a replacement delta pot, no longer available. With that being said ebay has quite a few with different ratings and am not sure which I would need.
Motor is 5 amp. Induction motor so am stuck with getting a replacement pot if possible.
   / Pot Question #3
take a picture so you know where the wires go, unsolder the pot, and measure the resistance on the outside terminals with an ohmmeter, that will give you the value you need for the new pot..
   / Pot Question #4
Does the pot have a number on it or a resistance value. You need to know the resistance and wattage and you can get a replacement if all else fails.
   / Pot Question
   / Pot Question
No numbers anywhere.
   / Pot Question
It's in 2 pieces, don't think I could get a value.
   / Pot Question #8
Does it go to some sort of board or electrical device or is it in line with the power that goes to the motor? Some pics would be good.
   / Pot Question
Yes it goes into a circuit board inside of unit, I haven't removed that because when I took front panel off to access the pot it came out in 2 pieces. This would tell me it's the pot that needs replacing.
Will take some pics and post a little later, I really like this grinder but can't sharpen tools at 3450 without that dreaded blue steel color.
   / Pot Question #10
If it goes to a circuit board it's a low wattage pot. Probably small. just need to figure out the resistance. If it's still intact enough you can measure it.
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2019 JOHN DEERE 8295R LOT NUMBER 183 (A53084)
2019 JOHN DEERE...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
Caterpillar Loader Quick Coupler (A52748)
Caterpillar Loader...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
