At Wit's end, clutch pedal return spring for 455D ???
   / At Wit's end, clutch pedal return spring for 455D ??? #1
DiskDoctr
Western PA
Mahindra 3510
We have a JD455D crawler loader with the foot pedal steering. The left pedal return spring is broken. I ordered one as close as I could tell and model, but it is far to large diameter and isn't right.
I have searched google, ebay, and any tractor part place I could find online, but no luck :confused:
I've been away so long due to illness that I was pleasantly surprised to find my login still worked!
If anyone can help me find this elusive part, I would be very grateful :thumbsup:
Thanks
   / At Wit's end, clutch pedal return spring for 455D ??? #4
   / At Wit's end, clutch pedal return spring for 455D ??? #6
You can go to the parts site, and look at the parts for the 455D
https://partscatalog.deere.com/jdrc/
Pic of the assembly where I pulled the part #
I saw the drawing you posted, but thought that was the traction clutch pedal, not a steering pedal. I hope that's the right spring! All I could find was lever steering and gave up.
I think you're right.
Here's a pic of the missing spring and its mate
   / At Wit's end, clutch pedal return spring for 455D ??? #8
Since there is plenty of room for a replacement spring, I would take the one you have to a Hardware store and see what you can find. We have Menards locally and they have plenty of springs in their specialty hardware sections
   / At Wit's end, clutch pedal return spring for 455D ??? #9
If all other sources fail; this spring is easy to make on a lathe.
   / At Wit's end, clutch pedal return spring for 455D ??? #10
this is what you're after I believe - (item #13). T14243 is the origonal number, but it subs to T143245
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
Tree Boom (A50322)
Tree Boom (A50322)
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
Walking Floor Trailer (A50322)
Walking Floor...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
