At Wit's end, clutch pedal return spring for 455D ???
   / At Wit's end, clutch pedal return spring for 455D ??? #1
DiskDoctr
Western PA
Mahindra 3510
We have a JD455D crawler loader with the foot pedal steering. The left pedal return spring is broken. I ordered one as close as I could tell and model, but it is far to large diameter and isn't right.
I have searched google, ebay, and any tractor part place I could find online, but no luck :confused:
I've been away so long due to illness that I was pleasantly surprised to find my login still worked!
If anyone can help me find this elusive part, I would be very grateful :thumbsup:
Thanks
   / At Wit's end, clutch pedal return spring for 455D ??? #4
   / At Wit's end, clutch pedal return spring for 455D ??? #6
You can go to the parts site, and look at the parts for the 455D
https://partscatalog.deere.com/jdrc/
Pic of the assembly where I pulled the part #
I saw the drawing you posted, but thought that was the traction clutch pedal, not a steering pedal. I hope that's the right spring! All I could find was lever steering and gave up.
I think you're right.
Here's a pic of the missing spring and its mate
   / At Wit's end, clutch pedal return spring for 455D ??? #8
Since there is plenty of room for a replacement spring, I would take the one you have to a Hardware store and see what you can find. We have Menards locally and they have plenty of springs in their specialty hardware sections
   / At Wit's end, clutch pedal return spring for 455D ??? #9
If all other sources fail; this spring is easy to make on a lathe.
   / At Wit's end, clutch pedal return spring for 455D ??? #10
this is what you're after I believe - (item #13). T14243 is the origonal number, but it subs to T143245
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2022 TAKEUCHI TB2150 EXCAVATOR (A51242)
2022 TAKEUCHI...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
71057 (A49346)
71057 (A49346)
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
