Top Five Frequently Used Construction Machines
   / Top Five Frequently Used Construction Machines #32
Not autonomous, but it takes a lot of the manual functions and automates them.
   / Top Five Frequently Used Construction Machines #33
I've been seeing more soft dig techniques being used on some job sites.
It's just become too expensive to risk digging up key infrastructure.
   / Top Five Frequently Used Construction Machines #34
Directional boring is the hot ticket these days. Saves a ton of dirt diggen.
B. John
   / Top Five Frequently Used Construction Machines #35
You want to see a grader look at a 24 G Cat but you have to run it..... I ran 11R CD's that had all the bells and whistles but a man could out work it...... jim
   / Top Five Frequently Used Construction Machines #36
B. John
Last year my neighbor's cable went out. Rather than run a new overhead wire, they sent out two guys and a small directional boring machine. They ran it under the road right up to his house and popped up. Then they pulled the cable back with it. Then they moved down the road about 100 yards to the box, and ran it right up into the first hole. Pulled the cable back to the box and left. Another tech came out and hooked it up. The boring only took about 15-20 minutes per run, so about 30-40 minutes total. I was impressed with the speed.
   / Top Five Frequently Used Construction Machines #37
I think the crushing equipment is also important construction machines you have to know. Mobile crushing equipment or fixed crushing equipment is the best machine to recycle waste concrete in the city because they can move flexibly with large capacity.
SKIDDED SHED (A55745)
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
HIGH END ELECTRIC GOLF CART (A55745)
HIGH END ELECTRIC...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
