Squirt extra bar oil on chain when cutting?
   / Squirt extra bar oil on chain when cutting? #21
I don't recall what brand it was or how old it was but but I do remember a few of the older saws that we had with manual oilers built in even with the auto oilers.
That's how my Homelite 450 Pro was equipped when I bought in back in 1980. Used to cut a lot of old dead and down juniper - stuff was so hard that the chain didn't produce shavings, more like fine sawdust. The manual oiler was wonderful with that stuff; I kept pouring the extra oil to the chain. If I didn't the chain would get very hot - no way the automatic oiler, though turned all the way up, could put out enough oil to cool and lube the chain in that dry dead wood. I used a lot of chain oil - but it saved me from having to replace the chains so often.
But the wood from that dead juniper was wonderful to burn - like burning coal - very hot fire with little ash, and fragrant to boot.
   / Squirt extra bar oil on chain when cutting? #22
As a kid my job was to cut up slab wood my father would buy by the truckload. All we had at the time as a McCulloch Mini Mac chainsaw. I have no clue if it had an automatic oiler but it had a manual one. I had no idea how much oil the chain needed so I would just push the bar down every so often. Funny how you read something and images of your past pop into your head that you haven't thought about in decades.
   / Squirt extra bar oil on chain when cutting? #23
I know some of the Old McCulloch Pro saws like the 10-10 and 700 had both .
A bit of a pain is setting the auto oiler because the oil tank cover must be removed to adjust it.
Oh, boy, same memories here. I had an old Skil chainsaw back in the early 1970's. They either merged with or had some deal with McCulloch. It was a low RPM (12,000 RPM ?) stinker of a saw that cut like you were driving fast over an old corduroy road. Hard starting and had a push oiler for the chain which is how I started adding oil in the first place. I thought that heavy saw was magic because I knew nothing else. We cut down huge trees even though it took a while. Sharpened the chain frequently and I think it took a 3/8" file. What a s-l-o-w and rough saw. Wow, have times changed.
   / Squirt extra bar oil on chain when cutting? #25
That sounds like a Homelite XL12. They actually were pretty tough saws for their time but turned so slow that you could sharpen the chain while cutting the wood.:D (Hey kids, don't try this at home!!)
   / Squirt extra bar oil on chain when cutting? #26
I don't recall the first chainsaw i used, but remember bar oil push button. My dad's saw was a blue Homelite from the early 70s, i'm pretty sure it was auto oil, because i remember checking by reving it and seeing how much oil flew off the tip. And like sixdogs, i thought it was pretty awesome saw, though it vibrated pretty good when cutting. My current 80s era Stihl is far beyond that old Homelite, though if i still had it, i'd have mount it up on the wall of my shop for all the memories i had with my dad, harvesting firewood. I rarely put oil to the Stihl, but have found a few instances where i thought it was prudent to add a bit.
   / Squirt extra bar oil on chain when cutting? #27
Those old blue Homelites didn't have an auto oiler. My father bought one to replace his big old McCullough and gave it to me when I wanted a saw. I did a lot of work with one of those before upgrading to a 254 Husky. I didn't like running without a chain brake and put both of my Homelites on the side of the road where they quickly disappeared; but like you I wish I had saved them.
   / Squirt extra bar oil on chain when cutting? #28
I once complained to my father about my hands getting numb from the vibrations from cutting wood for hours. He took the handle off and slid an inner tube from a bicycle around it. Now it not only vibrated but was much harder to hold onto as the inner tube would spin on the aluminum handle. I'm thinking a file and being taught how to sharpen a chain would have been much better as I'm sure most of my time cutting was with a chain about as sharp as a butter knife. I still have a Homelite XL12 somewhere. I think it's with an old Solo and Partner that haven't been touched in decades. Someday they will become wall art for the garage like the 30's era Black and Decker 3/4" drill I have.
   / Squirt extra bar oil on chain when cutting? #29
My spare saw is a Poulan… great for keeping in the back of the truck to take the occasional tree out of the road but I won't use it for long because of the vibration.
OK, also because it's a Poulan. ;) Years ago besides the Homelite I also had an old Arctic Cat snowmobile which I was using to get into the woods in the morning; again with no vibration dampening. After a while I noticed that I had no feeling in my hands for the first few hours of the morning. The two may or may not have been related but I stopped running that sled and haven't had a problem since.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
DRAFTING TABLE, METAL MOTOR STAND (A58374)
DRAFTING TABLE...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
