Who makes a good caulking gun?
   / Who makes a good caulking gun?
   / Who makes a good caulking gun? #22
Since a friend that does commercial glazing leant me his sausage gun, I have little use for the old tubes.
   / Who makes a good caulking gun? #23
I ordered one and it looks more impressive in person. Only problem is at the moment I have nothing to caulk. Maybe some day I'll give some feedback after using it.
It takes a little getting used to it, since it's like driving a hydrostatic compared to a geared machine. Most other guns you need to a clutch (release lever) or to twist the rod to get the caulk to stop flowing. With this gun, when you let up pressure on the trigger, the caulk stops flowing. And you can push or pull the plunger rod any time, with no releases needed. It also loads backwards, plunger end first, compared to other guns which load tip first.
   / Who makes a good caulking gun? #25
I've heard about the sausage gun, where do you get the sausages? How are they to handle (i.e. weight and balance)?
   / Who makes a good caulking gun? #26
Mostly trade outlets. Amazes me too, how you get the "GOOD STUFF" not the consumer grade, big box store junk. Most commercial sealants seem to be available in sausages. It's cheaper, doesn't seem to spoil as quickly and for big jobs, you are not changing tubes as often. Also, it seems to feed better than any conventonal (high end) tube style gun I have used.
Found This: How To Use a Sausage Gun - YouTube
I think the gun he is holding is the one I have. Hope my friend didn't want it back.
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2013 CAT 246C (A47477)
20 ft. Shipping Container (A53117)
20 ft. Shipping...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
