Who makes a good caulking gun?
   / Who makes a good caulking gun?
   / Who makes a good caulking gun? #22
Since a friend that does commercial glazing leant me his sausage gun, I have little use for the old tubes.
   / Who makes a good caulking gun? #23
I ordered one and it looks more impressive in person. Only problem is at the moment I have nothing to caulk. Maybe some day I'll give some feedback after using it.
It takes a little getting used to it, since it's like driving a hydrostatic compared to a geared machine. Most other guns you need to a clutch (release lever) or to twist the rod to get the caulk to stop flowing. With this gun, when you let up pressure on the trigger, the caulk stops flowing. And you can push or pull the plunger rod any time, with no releases needed. It also loads backwards, plunger end first, compared to other guns which load tip first.
   / Who makes a good caulking gun? #25
I've heard about the sausage gun, where do you get the sausages? How are they to handle (i.e. weight and balance)?
   / Who makes a good caulking gun? #26
Mostly trade outlets. Amazes me too, how you get the "GOOD STUFF" not the consumer grade, big box store junk. Most commercial sealants seem to be available in sausages. It's cheaper, doesn't seem to spoil as quickly and for big jobs, you are not changing tubes as often. Also, it seems to feed better than any conventonal (high end) tube style gun I have used.
Found This: How To Use a Sausage Gun - YouTube
I think the gun he is holding is the one I have. Hope my friend didn't want it back.
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
Hyster H225E Forklift (A47477)
Hyster H225E...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
