Tube gate wheels.
   / Tube gate wheels.
I don't favor drilling thru gate tubes cause that will weaken the structure at that point and be a path in for rust. I've got some "C" channel aluminum to use as backing and with band clamps to hold everything together works pretty good and a coat of paint blends it all together.
   / Tube gate wheels. #12
The gate posts here are strong enough that the gate does not need a wheel blue t u.png.
   / Tube gate wheels.
I see electric opener on that gate. So maybe the posts were concreted in?
   / Tube gate wheels. #14
Interesting thread.
My home brew 15' gate (made from chain link fence rails) has a solid caster wheel to help it roll into the closed position due to a sloped blacktop driveway.
I'm planning a rolling gate for my front yard entrance. Planning on a standard tube gate (for the structure) with fence boards added for privacy. Concept is to roll laterally behind the hedges. I'll need to level the area for the wheels to roll over, but it will either remain turf or get crushed rock or maybe pavers. I'm planning on manual movement, no power opener, so movement needs to be fairly easy. I'm not sure I want either solid or pneumatic tires,. but something in between might work well.
2006 John Deere 6320 (A50120)
2006 John Deere...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
Kubota BX22 TLB Compact Tractor (RUNS) (A50774)
Kubota BX22 TLB...
Hydraulic Lift Platform (A50121)
Hydraulic Lift...
2006 International 4400 DT466 (A50120)
2006 International...
