Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,741
I have a question for all you snow experts. I have a John Deere 4410 with about 38hp in the PTO. I have been looking at a new Frontier 60" 3 point hitch snowblower. I am wondering if I can upsize that to a 72"?
Also curious as to this brands reputation and durability. I looked at a Woodmizer online and it looks good too, but I don't know anything about gear durability, etc.
Open to ideas here, used units are few and far between and buying new is not too much more.
Thanks
I ran a Deere 4400 with a 72" Woods snow blower....worked good...might have to slow a bit on occasion
BTW, my 4400 with a reverser transmission put out 30 PTO HP...I suspect your 4410 is about the same
   / Pictures of your snow weapons #5,742
TractorData shows the following specs
John Deere 4410 Power:
Engine (gross): 34.6 hp [25.8 kW]
PTO (claimed): 30 hp [22.4 kW] (gear)
28.5 hp [21.3 kW] (hydro)
   / Pictures of your snow weapons #5,743
Engine (gross):34.6 hp [25.8 kW]
PTO (claimed):30 hp [22.4 kW] (gear)
Sorry either a typo in my head or off my finger! You are correct.
   / Pictures of your snow weapons #5,744
Personally, I would prefer a five foot blower where I could go faster, than a six foot and have to worry about overloading it. Given the snow and modest PTO hp, I think six foot is a bit too much.
   / Pictures of your snow weapons #5,745
Where I'm the opposite. I'm 72" on a hydro L3940. I'd love bigger (I think they recommend a 64"). If it's deep, I slow down. If not, I go fast. One slow pass or 2 fast passes moves the same snow. It's a function of HP on how much snow per hour (minute, whatever units you like) you can move.
   / Pictures of your snow weapons #5,746
I find that I make so many trips anyway to clean up windrows or spillage that the foot difference wouldn't make any difference so you might as well go with a slightly handier and more efficient size. I also get terribly bored when something is going too slow.
   / Pictures of your snow weapons #5,747
I ran a 72" blower on my previous Kubota L3410 (27hp PTO) and it was fine in the few storms where I used it. We don't get a lot of snow in my area, so the blower is for the once every few years storm we get in Maryland.
I did 25+ rural driveways after a 34" snow with this setup back in 2016 without issue, but it was slow going.
   / Pictures of your snow weapons #5,748
How wide is your tractor? When I purchased my Massey 1742, they equipped it with an 84" 3 pt blower. My tractor is a tad under six ft wide. Worked well, big snow, slow down. Light fluffy stuff, go like blazes. The tractor will tell you. Hydro makes you a pro.
   / Pictures of your snow weapons #5,749
i agree on how wide are your tires set apart... nothing worse than your tractor being wider than the blower width. a hydrostatic tractor is easy to adjust reversing speed. not so with my old jd870. it sucked when blowing snow. only 2 usable reverse speeds.
   / Pictures of your snow weapons #5,750
I had to go out and measure.... 58” from outside to outside. The Frontier I am looking at says it has a working width of 64” which would cover the tire tracks.
I think I am pretty settled on the width, just wondering about brand of Frontier which I have not used or other brands out there. I liked the Wood Maxx because it had an electric chute option. The Frontier has hydraulic chute only, and it would require an $6-800 addition on the rear hookups which run the front plow. I also plan to purchase a Cover My Tractor cab so the manual chute adjustment would not work.
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
