Advice on reloading press kit for beginner
   / Advice on reloading press kit for beginner #11
In my case I have a friend who has been reloading for decades, and he suggested that I spend some time on his press with him before going further. He says that it never saved him any money but sure did let him shoot a lot more.
I went with a single stage press because I don't have a clue what I'm doing and it seems like starting simple is best... plus it's what my wallet said I should do.
   / Advice on reloading press kit for beginner #12
You would be amazed by how many rounds you can due with a single stage press. That's how I started out then upgraded to a progressive. Still have and regularly use the single stage. The single stage allows you to work up a round to your liking, then daily in the other and crank out the rounds. Like others have mentioned, purchase a reloading book first. You won't save money reloading, but the accuracy saves you money! You can make the round for the need, plus it's a relaxing hobby for me. Good luck with your endeavor.
   / Advice on reloading press kit for beginner #13
And don't forget about a beginner reloading DVD video/s that you can watch over and over.
Here's a link to 1 (suggest you research as many as you can before deciding on 1):
KC
Brownells
   / Advice on reloading press kit for beginner #14
If you lived closer I would make you a sweetheart deal on about 30 pounds of stuff for a rockchucker RCBS reloading 9, 38, 357, 45 colt, 308 mag, 30.06 and maybe some I forgot.
   / Advice on reloading press kit for beginner #15
This little reloader is what Dad started with in the ‘60s.
We loaded 270 and 30.06.
Very basic, but affordable.
We used IMR4064 mainly, and some IMR4350.
   / Advice on reloading press kit for beginner #16
I’ve owned a Dillon 550 for about 25 years. I don’t think it’s any harder to learn on a progressive than a single stage. It’s doing the same thing, just all the steps at one pull of the handle.5DBF7FE5-9C06-4068-AADD-FFE138D27023.jpeg
   / Advice on reloading press kit for beginner #17
I’ve owned a Dillon 550 for about 25 years. I don’t think it’s any harder to learn on a progressive than a single stage. It’s doing the same thing, just all the steps at one pull of the handle.View attachment 678455
Agreed. If you can afford a good progressive press, I would advise to get one. You can always load one operation at a time just as with a single stage press if you want to really slow down and watch every operation. Nothing to prevent it, just put one case in at a time at position 1 and cycle it around until it drops into the cartridge box. Of course I had a single stage press at one time, but all of that screwing in dies and adjusting each time was just a pain in the ..... Of course the Hornady Lock n Load solved that. If you want a single stage press get a single stage press, but there is NOTHING wrong starting with a progressive press like the Dillon 550 or any number of its competitors'. You are still in control of everything, nothing is going to "get away from you".
   / Advice on reloading press kit for beginner #18
I started in 1980 with a used RCBS Rockchucker setup. Excellent way to learn, do load development, and produce excellent ammo for getting the most out of your rifle. If you are shooting handguns in quantity, you will want a progressive press. I started with a Dillon, but lost it in a spectacular fire. When I was able to replace it, I went with a Hornady Lock N Load auto progressive. Wholesale Hunter on Amazon is about $500 cheaper on it, delivery in January.
I prefer a single stage press for rifle, and a progressive for handgun, but as my time has become more valuable I have done very little reloading. This particular panic has extended to reloading supplies, negating that advantage. Back before California instituted the ammo transfer requirement, the wife and I decided to stock up on ammo. We looked at what we typically shot per year, and targeted ten years worth as our goal. Prices a couple of years ago were very low, availability was excellent, and the UPS driver came to hate us. Poor guy had five cases of 9mm and three of 45acp in our largest single shipment. In 18 months of buying, we reached our goal.
Watch the videos on YouTube. Realize that cases have to be collected and prepped, and prepping takes more equipment, space, and time. Back when I was shooting a Colt 45acp competitively on a very tight budget, that Dillon was doing a couple thousand rounds a month, at a third of the cost of new factory ammo, and the rounds were tailored to my gun and the task at hand. The Colt was kind to the brass, no dings or bulges, and low enough pressure to get 8-10 reloads out of the brass. And my time was cheap. Now, 40 years later, my volume is down, my Glocks mangle the brass, I can't reload the ammo I have on hand for what it cost me, and I have plenty of other things to do with my time. Given all that, my progressive press is not currently on the bench. One of my Rockchuckers is, and I can do everything I desire with that. If I were buying a new setup today, it would be a single stage press with quick-change die bushings, and an electronic powder dispenser. Either the RCBS Rockchucker or the Hornady LNL Classic would be my likely choice. Hornady sells bushings for the RCBS press.
   / Advice on reloading press kit for beginner #19
I have the classic with the quick change bushings.. I recommend only one caliber and powder on the bench at a time for safety, Become methodical in your methods, and keep accurate notes. I also perform ladder testing to develop very accurate bench loads for your specific rifle.
I wish I was to , because a sweetheart deals are few and far between, and just maybe I could pick up a few tips , I have read about the Rockchuker and most seem to really like it.
1667 (A57192)
1667 (A57192)
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2020 DRAGON ESP...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
