Iplayfarmer
Super Member
I posted about my new Terratrac GT30 crawler over in the "Projects" forum. Now that the initial enthusiasm and congratulations have worn off it's time to start the work of making it into what I need. The machine came to me with an electric hydraulic pump mounted behind the seat... Think dump trailer type pump. Not only is the wiring WAY wrong for it, but I'm sure the duty cycle would be wholly unfit for doing any real work. I'm going to re-build the hydraulic system with a real, engine driven pump and a real valve. I'm sure I'll need help along the way, so expect regular questions here.
The pump is from Surplus Center... 0.82 Cubic Inch. it should give me somewhere around 6-8 gpm at working engine RPM.
I have an old Jacobsen golf course reel mower that I'm scavenging parts from. It has a 3 spool valve, lots of hoses, filter, tank, etc.
I have two problems at present that I need to figure out:
1) The pump "does not have an out board bearing to support the shaft adequately under side load (pulley or chain drive) conditions." I was planning to belt drive off the fan belt, so I'll need to include some kind of bearing. I think I can figure this one out.
2) The real question that I have right now is that the lift cylinders on the sides of the loader are single acting. My valve is set up for double acting cylinders. How do I use a double acting valve on a single acting cylinder? Is it as easy as just blocking off the port that I'm not using on that spool of the valve?
