Kioti CK2510 50hr service - $$$
   / Kioti CK2510 50hr service - $$$ #21
Does your Kioti call for a hydro fluid changeout at only 50 hrs?
DEWFPO
No, its kind of conflicting. They call out for filter only. But i was getting different answers depending on who i asked, so i changed fluid also. Best to get any starting fluids out of tractor was my thoughts.
   / Kioti CK2510 50hr service - $$$ #22
DEWFPO
No, The manual doesn't call for it at 50 hrs. But many will recommend it. I changed mine at 50 hrs. and let it sit in the bucket for about a month before I took it for recycling. I was surprised how much sediment had settled at the bottom. For around $70, I feel it was worth the insurance.
   / Kioti CK2510 50hr service - $$$ #23
Yeah, it's pretty much a 50/50 split on opinions here as to whether change the hst fluid at 50 hours. On my last tractor I changed the fluid at 50h, and my current machine I did it at the 400h mark (by spec).
I prefer to do my own maintenance and repairs when possible. For my tractor the 400h service was around $400 in materials (maybe more). Paying myself $200-300 to do the work myself took the edge off.
   / Kioti CK2510 50hr service - $$$ #24
I think 650 is foolish for the 50hr if you are comfortable doing your own maintenance, do it, most likely you will do a better job then they would, I did all the fluids simply because I wanted to know what was used, didn't really have to but my comfort choice - one of the most important steps for you to do: torque / grease / tighten - I do not think I spent 200 doing everything including front axle - it will not jeopardize the warranty, I keep the receipts and mark the date done in the manual.
   / Kioti CK2510 50hr service - $$$ #25
I just went over 50hr of use on my Kioti CK2510.
I called the dealer to see about getting the 50hr service and they quoted me $650.00.
Wow. That seems high, but then I have not done it before so I don't know.
I can get the full set of filters on Amazon for about $125, and all of the fluids locally. I do my own auto maintenance. I assume I can do this as well??
It doesn't affect my warranty if I do it myself does it? $650.00 is a huge hit for me right now.
Support your local dealer - buying filters or parts from them helps keep the doors open. Amazon won't fix your tractor under warranty, so why support them.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
