Grandpa, tell me bout the good ole days............
Status
Not open for further replies.
   / Grandpa, tell me bout the good ole days............ #651
Tire sanders been around since 50s. Mostly useless but make management feel good.
https://elstonmfg.com/traction-sanders
Steam loco has sand dome sitting on top of boiler to keep sand warm & dry to flow in front of traction wheels to get moving. Works a little better than sander on truck. Train loco reverses first to use slack in couplers to advantage picking load with momentum of engine & front cars. Watch as train starts up, sometimes engineer gets a little ahead of himself on throttle and traction spinstill he cuts back.
   / Grandpa, tell me bout the good ole days............ #652
The old steam locomotives used to have a similar set up.
Some city plows have the sand chute flow ahead of the driver's side traction wheel.
That way they make it up hills and when broadcasting they cover the center section of the road surface so both lanes get a fair portion of abrasive.
   / Grandpa, tell me bout the good ole days............ #653
Current locos still use sand dispensing systems I believe.
   / Grandpa, tell me bout the good ole days............ #654
I got fed up and called the county about their sand trucks that handle the bypass near my home.
They sand intersections here, not the entire highway after a snow storm.
First couple of storms after we moved into our current house. Going down the bypass there were sanded patches of highway, the perfect width of an intersection. The perfectly sanded section started after each intersection though
I figured it out one morning when I got behind the plow truck. There was a 2 to 3 second delay from when it started to spool up till it actually started spitting out the sand.
I called the county and they were able to patch me through to one of the foreman so I could explain the issue.
   / Grandpa, tell me bout the good ole days............ #655
Some modern diesel locomotives have them too. If you look at the trucks, there will be a pipe on the front and rear axles to drop the sand on the rails.
   / Grandpa, tell me bout the good ole days............ #656
If some BO, puts grease on the rails, you need that. I was looking for the scene from Emperor of the North, but couldn't find it.
   / Grandpa, tell me bout the good ole days............ #657
Salt runs here all GPS controlled. Driver just along to keep truck on route. GPS set up by MisDirector of Department riding around in pickup some time during year. Odd thing, next town over got same equipment and ELECTED Highway Superintendent. Dey got cleaner pavement and better roads. Can't figure out why.
   / Grandpa, tell me bout the good ole days............ #658
You think the average citizen knows how best to vote on road maintenance?
   / Grandpa, tell me bout the good ole days............ #659
We have them too and in some places there are compressed air blowers just in front of the wheels to blow off the millions of millipedes that use the tracks to get to wherever they are going, after crushing a few thousand the just grinds to a halt and wheelspins, this fixed the problem but don't know if it unique to us.
   / Grandpa, tell me bout the good ole days............ #660
Sure dehel knows how many potholes he drives thru and how long dey take to get filled. Also knows how long his road takes gettin plowed after snow falls and how good job de plow driver does. First question voters should ask is can de boss run every piece of equipment. I know one in big town ain't got CDL and is scared of big trucks. He makes $127,000 a year for hiding in office wid air conditioning. Sure rather have de neignbors decidin on who Highway boss is den some fat politician takin care of one his flunkies.
Status
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A51692)
2018 Chevrolet...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
